I have wood!
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: I have wood!
    2001 Oct
    Madison, WI
    815
    I have wood!
    Well, its time to start weeding through what is left of my grandfathers wood collection. Unfortunatly his barn burned YEARS ago, where about 90% of the wood was. Most of this was cut 25-40 years ago. The majority of it is black walnut, and some cherry in there somewhere. Most of the large planks are at the bottom of the pile (also the ones I need). Most of the boards are rough cut, and about 10 ft in length. Width varies from about 4" to 14"+ Hoping to find the right pieces to have a guitar or 2 made from it. There is also a decent sized piece of ebony to use for the fretboard.. provided its a good piece.
    We have to break out one of the windows in the attack of his old vetrinary office (now a garage) to get the pile out.. they re-moddled around when he died, and converted the building into the garage, and left a lot of the heavy-impossible-to-move-out-of-the-attic-stuff up there .
    It would have been nice if my family had moved all of the heavy stuff out (like a very heavy wood lathe) BEFORE they took out the stairs.
    2006 Subaru Impreza STi
    Cobb 3" cat-back, Group N motor, trans, pitch stop mount, Whiteline diff bushings, RaceCompEngineering camber plates, Group N rear strut mounts, KW variant 3 coilovers.
    Burn-Up WRC replica hood, bumper, and carbon lip, WRC side mirrors, center gauge pod, EGT, boost, and oil pressure gauges, Prodrive mud flaps, Spec-C roof vent
    Just Lost Moderator Moraki's Avatar
    2004 Aug
    8,218
    Re: I have wood!
    Looks like you need a good planer
    In wine there is wisdom, in beer there is freedom, in water there is bacteria. -Ben Franklin
    2001 Oct
    Madison, WI
    815
    Re: I have wood!
    Your not kidding.. its going to take hours just sorting/moving the pile. I cant imagine how much work it is goin g to take making those pieces into usable wood.
    Must not get on internet after drunken nights at the bar. damn spinning keyboard
    2004 Aug
    8,218
    Re: I have wood!
    If you lived closer id drop by with my and help out
    That link is NSFW Lifetime Platinum MemberModerator bensenvill's Avatar
    2003 Aug
    Chicago
    14,355
    Re: I have wood!
    Quote Originally Posted by Moraki
    I have a full stand planer if you need the use of it... unlike dougs, its not movable but gives much cleaner cuts.
    if your looking for a whole seller for the wood, try stopping by Owl Hardwood with a few pictures [they deal with alot of exotic and rehabbed wood].
    I just started hemorrhaging blood from the sheer amount of rage that suddenly built up inside me from that comment.
    1994 Lincoln Towncar w/ 112576 CRUSHED
    1996 Contour SE MTX loaded w/ 137179 CRUSHED
    1999 Silver Frost MTX original owner w/ 70500 ALMOST RUNNING
    2009 Honda Fit manual w/ floormats
    2001 Oct
    Madison, WI
    815
    Re: I have wood!
    The large bulk of the wood is going to my uncles. I just get my choice of pieces for guitar building (maybe plus some extra). I will probably take you up on that offer Terry, when we move the pile out of the attic and I can actually remove the pieces I need. there is one huge board about 18" wide and about 3" thick at the very bottom of the pile.. provided there are no soft spots or knots, I think I am going to swipe that piece. there are also a few 6X6 center cuts that I think would be good neck material.
    2004 Aug
    8,218
    Re: I have wood!
    Quote Originally Posted by bensenvill
    The stand has nothing to do with how clean cuts are that only has to do with how perfect your edges are and a good feed motor helps too.
  9. #8
    2003 Aug
    Chicago
    14,355
    Re: I have wood!
    I can assure you a stand unit is infinitely superior to a portable unit.
  10. #9
    2004 Aug
    8,218
    Re: I have wood!
    Ive used a dozen different counter top and stand units and im afraid to tell you your TOTALLY wrong. Some stand units suck and some table tops kick ass. While most are EXACTLY the same model just bolted to a base or not.
  11. #10
    2001 Oct
    Madison, WI
    815
    Re: I have wood!
    I have 10 fingers
  1. Replies: 23
    Last Post: 2008-12-14, 01:00 AM
  2. Wood dash in a Cougar?!?
    By xxnyghtxryderxx in forum Interior Cosmetics
    Last Post: 2006-08-19, 07:55 PM
  3. Wood Dash kit?
    By mercurycougar in forum Interior Cosmetics
    Last Post: 2004-02-19, 11:51 PM
  4. Any Fiberglass/ Wood Cutting Experts out there?
    By Nemesis in forum COOGA NECO
    Last Post: 2003-08-09, 10:38 PM
  5. removing wood-trim dashkit?
    By lewis in forum How To's
    Last Post: 2002-03-02, 10:15 PM
