Rear seat clips...
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: Rear seat clips...
    Got 1/2 a Vanquish engine Lifetime Platinum MemberAdministrator JScullin's Avatar
    2000 Feb
    Badassachusetts
    11,330
    Rear seat clips...
    The lower half of the rear seats is held down with 2 clips in the front. Does anyone know if those are a one-time use thing or if there's a method to get them to clip in properly?
    Mine aren't locking in so I replaced them with a set from a junker and have the same issue. So I assume something is being damaged when they are first pulled out of their retainers.
    Skolenimation: Graphic Design | Modifications @ CougarDB.com
    Quote Originally Posted by BigBalledOX View Post
    This should be the thread that closes this forum permanently.
    NECO Member V6Singh's Avatar
    2006 Nov
    76
    The silly little clips break. To get the seat base to lock in you do have to push them corners down hard but if the clips have broken they'll need changing. There's a few Ford dealers here in the UK that still supply them for a few pounds. Think unpaid about £6 plus postage for mine about 2 years ago. They've not increased in price that I'm aware of.
    Above you! Gold Member ND4SPD's Avatar
    2001 Oct
    Canada
    15,875
    Re: Rear seat clips...
    Same - once removed, I was never able to get the seats secure again.
    ~Matt~
    2000 Feb
    Badassachusetts
    11,330
    Cursed things. Guess I'll pay the Ford tax. Sick of hearing them rattle going over bumps.
    2002 Jun
    Columbus, Ohio
    19,875
    How do you get the rear seats out without breaking those things, anyway?
    2000 Feb
    Badassachusetts
    11,330
    There's probably a special way you can get a flathead screwdriver in there. It has that flat piece on the back that probably pries it apart enough to lift the metal latch out and leaves the clip.
    Or, at just under $5/ea from Ford you buy 2 new ones and just tear them out.
    2000 Feb
    Badassachusetts
    11,330
    Part# F5RZ-54613A46-BB if anyone else wants.
  9. #8
    NECO Member 02cougarxr's Avatar
    2002 Feb
    307
    I"m going to be pulling my rear seats soon to get access to the fuel pump. mind take a picture of what it is I'm gonna be looking at?
    02 XR bought new in Jan. 02
    Lot's of Extras!
  10. #9
    2000 Feb
    Badassachusetts
    11,330
    Well, I already installed the new ones. When you pull the lower half of the seats up in the front you're going to have either white or black clips attached to metal loops. Pop them off with a flat head and install the new ones into the sheet metal before dropping the seat back in.
    You can try and find another way to pop them off. Maybe the Ford CD mentions it.
  11. #10
    NECO Member PzKpfw_III's Avatar
    2010 Aug
    Clifton, NJ
    1,542
    I've been wondering about that for a while now and thought I just did it wrong. It seems any sort of plastic clip in this car is a one time use part. Anyone know the part number for the clips that hold up the hatch liner?
    1999 Mercury Cougar Base ATX 2.5L w/post factory Convenience Package
    EPA Clean Air Section 609 Certified
