speedometer
Results 1 to 4 of 4
Thread: speedometer
    2007 Dec
    8
    speedometer
    i have a 99 cougar and i want to replace the speedo with the newer style is it a straight swap?
    NECO Member XGamer15's Avatar
    2008 Aug
    Mansfield, Ohio
    2,053
    Re: speedometer
    Garage Talk Non-Cougar automotive discussion, pictures & videos.
    Anyways here is a link to a good how to.
    How to swap your guages
    NECO Member c0alition's Avatar
    2007 Jun
    Amherst, MA
    942
    Re: speedometer
    Quote Originally Posted by XGamer15 View Post
    New style as in newer look or as in new year? Personally I don't think any of the gauges particularly look like a newer style, but I like my blue C2 faceplate. They make some customer faceplate but I don't know where to direct you to. If you search for faceplate though I'm sure something will pop up.
    Those who say it cannot be done should not interrupt those who are doing it.
    NECO Member fedeuruagu's Avatar
    2008 Feb
    Pompano Beach, FL
    1,867
    Re: speedometer
    all that helped a lot....
    yes it is a stright swap. u might want to keep your origial miles. all u need to do to keep the the original miles is to open the cluster, remove the gauge face from the stock one and put in the gauge face from the 01-02 cluster.
    2000 3.0L MTX Laser Red 201whp/183tq - SVT Cams - UIM - LIM - TB - Clutch. Fidanza. B&G - Sensatrac. Konig - Toyo. MSDS - Monza Pace Setter. B&M. SCT. Pioneer. VIS - Roush.
    Car Domain
  1. Speedometer
    By CougarDan in forum Problems
    Last Post: 2009-12-06, 08:23 PM
  2. Speedometer
    By Kryptical in forum Problems
    Last Post: 2008-09-04, 06:17 PM
  3. will my speedometer be off???
    By AEMCougar in forum Wheels,Tires & Brakes
    Last Post: 2003-10-14, 08:50 PM
  4. Speedometer
    By TwistedXzibits in forum Problems
    Last Post: 2002-03-21, 05:06 PM
  5. Speedometer is off?
    By Sneak in forum General Info
    Last Post: 2001-10-17, 05:16 PM
