Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: Front Strut Bar How-To
    NECO Member ClaymoreWW's Avatar
    Mar 2005
    Battle Creek, MI
    1,618
    I installed a Freedom Design Front Strut Bar today and thought to write up a how-to for others. This would also work for the OMP bar. I apologize for the poor pics...I think my camera mal-adjusts the settings on flash. This is a very easy mod to do. If you follow these directions, you should have no problems. It took me an hour - and that was including time to lay out the photos. I had never installed one of these bars before, but it is very straight-forward. This is so easy that if I had the tools assembled and all ready to go, this should take no longer than 20 minutes to install.
    Step 1. Gather your tools. I used an electric drill with two bits: a small bit for the pilot holes and a 3/8" bit for the holes. You will need a tool to install the nut-serts (blind nuts) - this tool and several adapters and various sizes of nut-serts cost me $10 at the local home store. Make sure your kit contains 1/4-20 nut-serts. Also, you will need six 1/4-20 x 3/4 bolts, six flat washers and six lock washers.
    Step 2. Place the bar in location. Use the turnbuckle adjustments to locate the mounting pads around the strut end. Whne the bar is located properly, use a sharpie marker or the like to mark where you will need to drill the holes.
    Step 3: Carefully drill the pilot holes and then drill the larger holes.
    Step 4: Following the directions on the Nut-sert tool kit, install the six nut-serts in the drilled holes. These work somewhat like pop rivets.
    Step 5: After all nut-serts are installed, place the bar back in position. Place a lock washer on a bolt and then a flat washer and then loosely screw into one location. Keep this loose - this will allow you to locate the other two bolts on the side. Note that the 3/4 inch long bolts are just long enough, but may be tricky to start. This is due to the nature of the nut-sert and the stack of washers and how the base of the bar mount is not exactly flush with the surface of the tower. Take your time and get a few turns on each of the three bolts before you tighten them down. Repeat for the other three bolts on the other side.
    Step 6: Tighten all six bolts and then make sure that the turnbuckle nuts are tight on the bar and the bolt/nut combos are tight where the bar attaches to the mount pad. Sit back and enjoy your efforts.
    --george
    2000 Rio Red 2.5L MTX - see mods in links
    CF2K6 - 3rd Interior, 3rd Exterior --- CF2K7 - 2nd Interior, 3rd Exterior
    Me on CougarDB - Me on TeamNECO - Me on MotorTopia
  2. #2
    Moderator Moderator J-Man's Avatar
    Jun 2004
    IOWA
    12,245
    Re: Front Strut Bar How-To
    thank you very much, this will help tons in the near future.
    man i really owe you with how much you've helped me
    '01 DSG
  3. #3
    NECO Member world-insight's Avatar
    Oct 2005
    columbus GA
    1,305
    I'm having trouble with the OMP bar. keeps hitting a little round thing at the rear right of the UIM if you were standing in front of the car. It hits that and doesn't allow me to get the ends all the way down on the strut mounts.
    2004 Pontia Grand Prix: 20in Driv Gt, Nexxen tires, Crossed Drilled and Slotted Brakes, Chrome trim molding, Custom Exhuast, SE Rear Lip, Two tone Paint. many more to come.
  4. #4
    Seeking Deification Platinum Member nadthomas's Avatar
    Feb 2003
    Grove City, OH
    4,313
    Dude, that is awesome, I never thought about using nut-serts for that, I am so doing that this weekend. I have been trying to think of a better way to mount them as both of mine have stripped out the holes using self-tapping screws.
    2001 C2 3L ATX -SVT UIM/TB, CAI, B&G Springs, MSDS Headers, Optimized Y-pipe, B&M Oil Cooler, Konig Hurry
    Lucky Number 3.
  5. #5
    NECO Member CincyZetec's Avatar
    Jun 2005
    the nati bishes!!
    1,357
    where did u get the nut-sert? i went to 2 hardware stores and they've never heard of it.
    Sales Person: "Nothing makes you feel more like a man than a Thundercougarfalconbird. So how much were you thinking of spending on this Thundercougarfalconbird?"
    Fry: "Sorry, I'm not here to buy."
    Sales Person: "I understand and it's wonderful that you don't care whether anyone questions your sexual orientation."
    Fry: "I care! I care plenty! I just dunno how to make them stop!"
    Sales Person: "One word: Thundercougarfalconbird."
    2002 black 2.0L mtx
    proud to b the "runt" of ohio
  6. #6
    NECO Member michcougar's Avatar
    Jan 2004
    Fort Erie, ontario
    2,874
    Ya where can you get them?
    i just bought my freedom design brace and im missing 1 of the inserts.
    MICH,
    99 Laser red 3L Roush Cougar
  7. #7
    Nov 2002
    Cincinnati
    2,238
    1999 Laser Red MTX
    14.509 1/4 2.265 60'
  8. #8
    Jun 2005
    the nati bishes!!
    1,357
    a store? i would like to go buy it and b able to use it today, i don't want to have to wait a week to get it in the mail.
    2002 black 2.0L mtx
  9. #9
    is watching you. Lifetime Platinum MemberModerator sonza68's Avatar
    Jan 2001
    Right behind you
    12,608
    Harbor Freight has store fronts too, but there might not be one right near you.
    Show me who to smite and they shall be smoten.
  10. #10
    NECO Member Honzo's Avatar
    Nov 2007
    Jacksonville, FL
    1,017
    bumpity
    how do these nut-serts work? i wanna do this but i hear self tapping screws strip out and actual nut and bolt methods require removing the strut...
    Quote Originally Posted by EternalOne View Post
    Best part was when they told me the hotel went non-smoking. Brad asked how I'd survive, and I (while still standing at the check-in desk) told him, "I'll just smoke in the room, and before I leave I'll pee all over to cover the smell." The look on that guys face at the desk was classic. =)
    E1
  1. Front Strut Bar
    By mrcougar1999 in forum General Info
    Last Post: 04-29-2009, 06:39 PM
  2. front strut bar
    By 19predator99 in forum WTB: Automotive Parts & Accessories
    Last Post: 07-23-2006, 02:25 PM
  3. front strut bar
    By 19cougar999 in forum Suspension Performance
    Last Post: 07-21-2006, 11:49 AM
  4. Front Strut Bar
    By silvacouga in forum Suspension Performance
    Last Post: 03-23-2005, 09:51 AM
  5. HELP With Front Strut Bar!!!!
    By DanielPajak in forum Suspension Performance
    Last Post: 11-14-2003, 06:39 PM
SEO by vBSEO
