| How To's Do it yourself modification and maintenance tips and tutorials. |
#71 (permalink) |
Re: How To: End the ATX 1-2 Bang Shift!!!
Well I got the sensor and installed it. Battery was unhooked and everything reset and sure enough it is still there. I notice when I put it in drive it will buck into gear at times but other gears are fine. The fluid seems good doesn't smell burnt but I was gonna change it anyway cause I am not sure when it was done last. There is no slipping that I can feel. It is only a hard shift between 1 and 2 with a little buck when downshifting into 2 on throttle. I was thinking maybe a roll resistor mount?? The front one looks okay but I haven't looked the back yet. I will reset the computer one more time but I don't think it will help.
#74 (permalink) | |
No wonder I couldn't see them. :D Can someone pls post them again? I am mechanically challenged but I do think is worth to try this before I take the car somewhere else. Looking at the step by step pics will definitely help. I figured that if it doesn't work it will be $ 20.00 and 15 mins of my time. |
#76 (permalink) |
Ford parts online is gone where can I order this from cause my mechanic says I need it
Those who choose to stand in the back of the crowd will never be remembered but those who courageously stand out away from the crowd will never be forgotten.[SIGPIC] |
#78 (permalink) |
Om Mani Padme Hum
Sort of a road tale, but when I swapped the sensors back in July of 03, the stock Cougar jack sunk into the pavement and failed when I ran upstairs to get something.....Coug came crashing down on the rotor.
I managed to get my ex-gf's jack under it only for it to fail too. ![]() Luckily the rotor was fine. ![]() |
#79 (permalink) |
Changed my sensor a while back and made no difference at all. Still a bump shift between 1-2 and changed the fluid as well and still the same thing. I guess this doesn't work in all cases.
#80 (permalink) |
Update: Just found out my front and rear roll resistors are toast so i am really wondering if that is causing my bump shift and sometimes clunking when put in D from Park. Everything else checks out. Guess my sensor wasn't bad to begin with?
