Go Back   NECO Forums > Modifications > How To's
How To's Do it yourself modification and maintenance tips and tutorials.
Old 04-21-2003, 09:33 PM   #11 (permalink)
99CouGSweetRide's Avatar
How to end the ATX 1-2 Bang Shift!!!
wait...why would you stomp on the gas and then let it go? That's a good way to destroy your tranny
Mike
2006 Pontiac G6 GTP Coupe
1999 Mercury Cougar
Current Favorite DJs/Songs: Alex Megane - Little Lies, Alvaro - Piece of Your Heart, Cascada - How Do You Do, Gigi D'Agostino - Those Were the Days, Sven-R-G - Drift Away, Da Franco - Without You, Scooter - Hello (Good to be Back), Tune Up! - Feel Fine
99CouGSweetRide is offline
Old 04-22-2003, 01:02 AM   #12 (permalink)
Images: 732
You floor it ... the guy in front of you brakes ... you have to step off the gas or apply the brakes. The instant you step off the gas, the car violently slams into 2nd's gear. Ford knows that this is a problem, otherwise they wouldn't have fixed the sensor.
Old 04-23-2003, 05:04 PM   #13 (permalink)
MrFroge's Avatar
It looks like there is a metal gasket under the sensor.. should this be changed also??
MrFroge is offline
Old 04-23-2003, 05:15 PM   #14 (permalink)
Images: 732
No, the gasket looking thing is the flange of the old sensor. Prying at the flange with a screw driver will not work ... you need to "pull" it straight out with some locking/regular vise grips.
Old 04-23-2003, 07:29 PM   #15 (permalink)
why would you floor it if someone is in front of you? lol sorry.
Mike
1999 Mercury Cougar
Old 04-23-2003, 08:52 PM   #16 (permalink)
maybe you and the other driver floor it at the same time because youve been following eachother for a while then a squirrel/baby carriage/pedestrian............runs/rolls/walks in front of the guys car he hits the brakes you hit the brakes the car slams into second gear...................there you go, now just change the damn sensor
denn is offline
Old 04-24-2003, 01:44 AM   #17 (permalink)
mhmm.. sounds good! and can I get this from a mercury dealership or FPO only?
Mike
1999 Mercury Cougar
Old 04-24-2003, 12:41 PM   #18 (permalink)
Ill be doing this tonight, finally getting around to fixing something besides an audio componenet.
Mazda 3'n around town now-
Last I heard the cougar was rolled into a sand dune.....should of kept it.
Lukydogg is offline
Old 04-24-2003, 05:30 PM   #19 (permalink)
BabyLove is 1!
MetallicaCougs's Avatar
I actually had this happen last night. I was taking off at a light when some idiot pulled out in front of me. I had to slow down to keep from hitting him.
MetallicaCougs is offline
Old 04-29-2003, 08:09 PM   #20 (permalink)
Grendel
Guest
Posts: n/a
Okay, I received mine from the for dealor, $25.
KIT:
XS7P-7M101-KT
Part numbers:
-7M101- "Turbine Shaft Speed Sensor" qty:1
W500213-S309 "Mounting bolt" qty:1 (Missing in my packet)
SK XS7P-7M101-AA "Instruction Sheet" qty:1
Anyways, the new bolt:
16mm <EDIT> SCREW M6X16 HEX FLNG PIL 8 - As listed by Fordpartsonline.com</EDIT>
Old bolt:
12mm.
As soon as I can get the larger bolt, I will be doing this.
