GI: NECO Forums Sequentially numbered Badge
Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 10 of 50
Thread: GI: NECO Forums Sequentially numbered Badge
    Buyer Beware
    2008 Sep
    76
    Smile GI: NECO Forums Sequentially numbered Badge
    Custom made name badges for the NECO forums
    Each badge is sequentially labeled beginning with #0001 to #0100. Please note that these are limited edition badges. The number can be increase from 100 to 150 or 200 if enough interest is there
    Since badge numbers are unique, if you see a car on the road with a specific badge number, you can look up what member that was on the cumulative GB List!
    Specifications:
    3" x 1" 1100 Alloy Aluminum with Brushed/Satin Finish with a hard anodized clear coat.
    3M VHB (Very high bond) mounting tape
    Strength: 25 lb/in of 90 degree peel adhesion strength (440 N/100mm)
    Anodized / Clear Coat Specs:
    Mil-P-514
    Mil-P-15024D Type H & G
    Federal Spec GG-P-455B
    Description:
    Chemically anodized black and blue dyes followed by a mil spec anodized clear top coat. The result is an image that is chemical resistant, and highly durable for outdoor applications in direct sunlight and in salt water conditions. The plate of metal itself would have to be destroyed to affect the image due to the state of the art manufacturing. Traditional silk screen or printed badges has color that can scratch off with your fingernail, and the colors fade in UV light... These military spec bad boys do not have a raised ink surface and will last a lifetime.
    Each badge has been anodized and CNC cut from a sheet of 0.050" aluminum alloy sheet which is very robust. In addition, each badge is backed with 3M 4949 VHB Black foam tape. This is a premium mounting acrylic/rubber-like pad that will allow your badge to mount to your exterior paint, or textured surface plastics. Designed as an exterior fastener to replace rivets, spot welds, and liquid adhesives, 3M VHB is made of a viscoelastic acrylic foam that is energy absorbing with outstanding durability. (UL746C)
    The acrylic adhesive is 100% resistant to full submersion in water, salt water, hydraulic fluid, 10w30 motor oil, and glycol antifreeze. 90% resistant to kerosene, 50% resistant to jet fuel, 35% resistant to gasoline, and 5% resistant to MEK (Methyl Ethyl Ketone).
    If applied at room temperature, 50% of ultimate bond strength will be achieved after 20 minutes, 90% after 24 hours and 100% after 72 hours. The higher the temperatures, the faster the curing time.
    Installation:
    PLEASE make sure the badge is exactly where you want it to go before applying it. This means first taping the badge to the location you want and checking that it's not crooked. Next, outline the badge with tape to mark the location. Finally, peel back the clear plastic liner and apply firmly to virtually any surface that is clean. The bond will be strong, however it can and will remove cleanly without leaving a residue. Just apply about 90 lbs peeling force and the "rubber like" adhesive removes cleanly.
    If we can get enough interest for there badges, I can have them made ASAP and have a GB started. But I will need the approval of the admin to use the forum's logo first.
    I will reserve the badges number 0001-0004 for the admin and support staff, and the rest of the numbers will be available to the rest of the members
    I have attached the badge I have made for a Focus forum.
    [B][url]www.darkstarmotorsports.com[/url][/B]
    [URL="http://www.newcougar.org/forums/group-buys/130765-gi-neco-forums-sequentially-numbered-badge.html"]**GI; NECO Forums Sequentially numbered Badges [/URL]
    Buyer Beware
    2008 Sep
    76
    Re: GI: NECO Forums Sequentially numbered Badge
    Tell me what you guys think about these.......
    NECO Member azbobbybooshay10's Avatar
    2004 May
    Williams, AZ
    7,252
    I think this is a pointless and stupid item. Our cars weren't produced in any official "sequence" or anything, like SVT Contours or other limited-production cars, so putting a "badge number" on your Cougar is totally pointless.
    So there, thats what I think of this.
    1999 Black Mercury Cougar V6 MTX - "Sonic" - Resurrection nearly complete! -.
    1999 Silver Frost Mercury Cougar V6 MTX - "Silver"
    1989 Jeep Cherokee 4.0 4x4 - "Tails"
    Buyer Beware
    2008 Sep
    76
    Quote Originally Posted by azbobbybooshay10 View Post
    Your car is not the only place you have to place this. And the sequential number is not about you "car" it's about being part of the community.
    Got 1/2 a Vanquish engine Lifetime Platinum MemberAdministrator JScullin's Avatar
    2000 Feb
    Badassachusetts
    11,330
    I someone agree with bobby. The idea of a metal logo in of itself would be a cool idea and I'd like to see it done if Trevor (Fastcougar) approves.
    But the sequential thing wouldn't make any sense unless it was aimed strictly at the Roush owners. Who's cars are of limited run.
    Skolenimation: Graphic Design | Modifications @ CougarDB.com
    Quote Originally Posted by BigBalledOX View Post
    This should be the thread that closes this forum permanently.
    be trollin fer trolls Lifetime Platinum MemberAdministrator FastCougar's Avatar
    1999 Nov
    Kearneysville, WV
    8,487
    Agreed, how about the logo (needs redesign) and below that, your forum screen name?
    Former owner of a 1999 Mercury Cougar - Turbo'd 3L "Mavro Gato".
    For Sale: Turbo Cut Heads (w/SVT cams), All New Timing Equipment - PRICES SLASHED!
    2007 Oct
    Louisville, KY
    1,294
    Quote Originally Posted by FastCougar View Post
    +1, but I do like the # concept, but we have no use for that.
    2000 Silver Frost... raped and taken.
    Quote Originally Posted by XGamer15 View Post
    No just, "shut up!" and he slammed his laptop closed.
    You should try that yourself.
  9. #8
    HTRD LKN Lifetime Platinum Member BBOX's Avatar
    2002 Apr
    Chicago
    22,628
    This I would be interested in!
    2010 Lincoln MKS Ecoboost - Cinnamon Clearcoat Metallic
    1999 Mercury Cougar - Melina Blue
    Heal them, with fire from above.
  10. #9
    2002 Jun
    Columbus, Ohio
    19,884
    Indeed a much better idea.
  11. #10
    Va te faire foutre Lifetime Platinum MemberModerator Goldie's Avatar
    2002 Jun
    Portland, Oregon, United States
    6,131
    Quote Originally Posted by darkstarmotorsports View Post
    IMO, chances of seeing another cougar on the road, with one of these 100 badges (assuming you were actually to sell 100 and those 100 were placed on the car) is the equivalent of a needle in a haystack - except at a NECO event, where you would know who's car is who's anyway.
    there are now nearly 10,000 NECO user names and of those, I would guess there are around 500 that are currently 'active' (just a wild guess). maybe 5% would be interested in purchasing and placing this on their car (25 cars).
    since in the 6 1/2 years I've been on this board, there has been 1 time I had a random NECO encounter, I would say my chance of running into one of these is about .00005% (percentage was not based on anything mathmatical, but you get the point I'm sure).
    2000 Cougar V6, Citrus Gold, Born on 8.30.99 CougarDB CarDomain
    2008 Pontiac Solstice GXP 2.0L Turbo, 'Cool' Lt Tarnished Silver, Born on 9.21.07
  1. GB: NECO Forums Sequentially numbered Badge
    By darkstarmotorsports in forum Group Buys
    Last Post: 2009-09-22, 10:47 PM
  2. NECO Forums License Plate Frame
    By FrankMcG in forum FS: Automotive Parts & Accessories
    Last Post: 2007-03-27, 11:01 AM
  3. OHIO NECO=KING OF REGIONAL FORUMS!
    By OSUStallion in forum Ohio NECO
    Last Post: 2004-04-30, 11:10 AM
  4. Midwest Neco Icon/Badge
    By Nipanther in forum Midwest NECO
    Last Post: 2003-05-14, 12:06 AM
  5. NECO Forums
    By ZnCoug in forum General Info
    Last Post: 2001-08-28, 09:55 PM
