New Indiglo Gauges - Needles Sticking
Results 1 to 10 of 10
Thread: New Indiglo Gauges - Needles Sticking
    NECO Member highgeer's Avatar
    2000 Nov
    Denver, CO
    580
    Ok - I installed my new Indiglo gauges from Cardoc at Speedpeople this weekend. However, my needles are sticking and therefore not accurate. I figured this might kind of "go-away" but it hasn't. My speedometer will say I'm doing 55mph when I'm really doing 80mph (I have the car in diagnostic mode)! Plus, my fuel tank needle is sticking pretty badly also.
    Cardoc, if you're out there, can you pease tell me how to get around this? If anyone else has a method for solving this - preferably without disassembling the whole dash and cluster again - I'd really appreciate it! Thanks!
    -Jeremy
    2003 Suzuki SV1000 V-Twin
    2000 Mercury Cougar V6 - SOLD
    1973 Ford Bronco V8
    2004 Nissan Titan V8
    NECO Member StreetConcepts's Avatar
    2000 Oct
    3,739
    1) fill your gas tank
    2) disassemble cluster
    3) remove needles
    4) disconnect & reconnect battery
    5) turn key on and then off and on again
    6) the cluster will calibrate itself
    7) install gas needle and temp needle with key on
    8) turn key off
    9) install speedo and tach needles
    10) test drive and confirm accuracey
    11) put cluster back together
    Craig Flango
    Operations Director Kreative Import Technology
    kreativeimport.com
    Co-Owner Krazy Kustomz Online
    3% NECO Discount Coupon Code 'NECO'
    krazykustomzonline.com
    2000 Oct
    1,649
    Craig, good tips.
    Also remeber to not push the needles down so close to the gauge face. I did this and mine stuck as well. What I did was pull them up off the gauge face and turn the lights on. Underneath the needle a round glow of light would appear I just pulled up or pushed down the needles until the round circles were even.
    Not the fault of the gauge face just the install, don't worry its not a hard fix just time consuming.
    Former SC 3L Roush cougar owner
    I offer Port and Polished heads, please vist my web site PnPheads
    2000 Nov
    Denver, CO
    580
    I thought the whole idea of these slip-on gauges was you wouldn't have to remove the needles and do all of that calibration?!
    Additionally, I don't think removing the needles and doing all the calibration will solve my problem - I never removed the needles in the first place. It's not that the needles are out of calibration, it's that they are getting stuck on the new gauge face material, so they can't get to the proper position. For instance, as I accelerate, my needle goes to about 10 and sticks. It jumps again to about 45 when I hit 45mph and sticks. And not until I hit 55mph does the needle move from 45. The needle sticks at 55 until I reach about 75-80mph, where it jumps to the proper position.
    Thanks to StreetConcepts and Kinger for the how-to, but I think that's more for replacement gauges that require removing the needles and stock gauges. I know a number of you out there bought these Indiglo gauges and have installed them - am I the only one having this issue?![img]custom_images/emoticons/shocked.gif[/img]
    1973 Ford Bronco V8
    NECO Member Ripple's Avatar
    2000 Oct
    1,017
    Yeah I'm having the same problem with mine also. I've been driving with my lights on so that it would help flatten out the new gauges. They're supposed to "settle" after a while but still haven't.
    Mowgli
    Guest
    Same here, I just think that you and I will have to pull the needles out just a bit further to accomodate the thickness of the overlay gauges. I had mine between two phonebooks for over a week to flatten them out after shipping. Mine sticks at 80mph and at 5000rpm but the other two needles don't stick. Hope that helps.
    Moderator Moderator Estiem's Avatar
    2000 Oct
    Honolulu, HI
    1,975
    how did you adhere your gauges to your cluster? i had mine in the box until a few minutes before install. my needles stick, mainly cuz i think the lil loops of tape aren't holding down the gauges like i thought they would. hehe. whoops.
    i'd give it some driving. diagnostic mode is cooler anyways. but yeah, it's a hassle. just give it time.
    Mele Kalikimaka
  9. #8
    2000 Oct
    304
    I had the needles stick on my gauges as well on the first try. I found it difficult to get the indiglos on without removing the needles (too much stress on the indiglo gauges around the holes). Simply use 2 spoons and pry them underneath the needles to pull them out a little. You can pull them out quite a bit before they actually come off the post. Problem solved!
    FOR SALE $12000 OBO: Black/Black 2000 Mustang GT, 5 Speed
    ...Tastefully Modded...
    13.500 @ 102.04 mph (street tires)
    13.285 @ 103.90 mph (Nitto DR's)
  10. #9
    Shady
    Guest
    The needles stick right a=round the holes. I had the same problem and had mine apart 3 times now. You may have to do a little bit of light filing around the holes where the needles go through. I filed mine a bit and now the only one that sticks is the one for the gas. I will probably have to pull them back apart and pull the needles up a bit more. Good luck, Brad
  11. #10
    2000 Nov
    Denver, CO
    580
    I think I'll put a call in to Dominic (Cardoc) at Speedpeople since this many of us are having problems. Maybe he's already heard it and solved it, but hasn't mentioned it to us? Otherwise, SpruceCougar's solution looks best.
    I didn't do anything to adhere my gauges - I didn't see any reason to. I lined them up real good and was very meticulous when I put the black plastic frame and clear shield over them. They're all nice and centered and lined up, but the damn sticking needles!
    1973 Ford Bronco V8
  1. Indiglo Needles
    By skull_heaven in forum Interior Cosmetics
    Last Post: 2007-03-27, 11:18 PM
  2. Indiglo needles with indiglo gauges
    By mindtrip1016 in forum Videos & Pictures
    Last Post: 2002-08-15, 01:39 AM
  3. Needles Sticking and Help calibrating
    By BeachCougar in forum Problems
    Last Post: 2002-07-17, 01:42 PM
  4. How to make Indiglo Needles!
    By Icefury in forum How To's
    Last Post: 2002-05-27, 02:06 PM
  5. Gauge faces and Indiglo needles?
    By MrFlesh in forum Exterior Cosmetics
    Last Post: 2002-01-18, 09:23 AM
