My Trunk Will Not Stay Open . . .
Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 10 of 45
Thread: My Trunk Will Not Stay Open . . .
    2008 Mar
    Houston,TX
    21
    Does anyone know the actual name of the bars that hold the trunk open? I am in need of replacing these parts. If anyone can help, please message me. Thanks.
    I like whine and TT's Moderator iceberg65's Avatar
    2007 Apr
    Medicine Hat, AB
    3,108
    Re: My Trunk Will Not Stay Open . . .
    they are called lift supports. if you go to rockauto.com they are like 18 bucks I think. just navigate through the catalog to cougar its under "body-exterior" then "lift support" they range from 12-20 dollars
    The ONLY Supercharged Zetec Cougar! (C'mon, somebody else do it!)
    00 JRSC 2.0 Cougar
    13 Taurus SHO
    04 Ram 2500 on 35's and 6" long arm
    NECO Member Stealth's Avatar
    2008 Nov
    Nashville, Tennessee
    124
    Good thread. I'd've gone with trunk struts but now I know better. Just got a set yesterday from the junk yard, pulled them off an 02 with front end damage for like 5 bucks.
    -Difficult is driving a manual trans in 3 inch heels.
  5. Remove Advertisements
  6. #4
    2008 Mar
    Houston,TX
    21
    Thanks. I really appreciate it.
  7. #5
    w00t! Gold Member ND4SPD's Avatar
    2001 Oct
    Canada
    15,782
    Are you sure the trunk is just not staying open because its cold out? That happens to a few people (myself included) every winter.
    There are also two types of lift supports... the stock replacements are rated for 75lbs each if I remember right. (Hatch + glass weighs 150lbs) and then there are heavier duty ones that are rated higher (can't remember how much, but a few people have them, and their trunk literally FLIES open if you don't hold onto it past a certain point. Not joking! )
    Those are the one's I would get if I were replacing them. The stock ones feel as if a strong wind could close the trunk on your head if you aren't careful.
    ~Matt~
  8. #6
    NECO Member madcustomz's Avatar
    2007 Dec
    Wyandotte, Michigan
    1,099
    Quote Originally Posted by ND4SPD View Post
    That has happened to me before i thought i was going to be decapitated.
    Quote Originally Posted by kustomcougar View Post
    i'll whack it tomorrow, might not be able to whack it to hard because its in a tight fit
    Quote Originally Posted by B3NN3TT View Post
    kustomcougar just rarely knows what he's talking about. You'll find that out.
  9. #7
    2008 Nov
    124
    Doesn't even take a strong wind sometimes.
  10. #8
    2008 Mar
    Houston,TX
    21
    I am certain that my problem has nothing at all to do with the weather. In fact, this has been happening for quite some time now. I decided that I would log in to ask fellow Cougar owners.
  11. #9
    NECO Member KUU6AR's Avatar
    2009 Jan
    Plover, Wisconsin
    271
    I've got the same problem. When I got the car in the summer, the trunk worked fine, but once winter and the cold @ss weather came around, my trunk's been trying to eat my head ever since. I thought it was the weather.
  12. #10
    Va te faire foutre Lifetime Platinum MemberModerator Goldie's Avatar
    2002 Jun
    Portland, Oregon, United States
    5,997
    Quote Originally Posted by KUU6AR View Post
    it partly is the weather. Mine works fine in the summer, and when cold (and more so if gold and covered in rain/ice) the struts will not stay up. But then, they are 9 years old.........
    2000 Cougar V6, Citrus Gold, Born on 8.30.99 CougarDB CarDomain
    2008 Pontiac Solstice GXP 2.0L Turbo, 'Cool' Lt Tarnished Silver, Born on 9.21.07
  1. Trunk won't stay open
    By JChaseDead in forum Problems
    Last Post: 2007-12-29, 09:29 AM
  2. trunk won't open
    By cougardude22 in forum Problems
    Last Post: 2006-10-30, 11:13 PM
  3. Trunk wont open, hood wont open, loose handle.
    By LeValley in forum Problems
    Last Post: 2003-11-05, 11:21 PM
  4. Vents Won't Stay Open
    By Aries in forum Problems
    Last Post: 2002-08-06, 01:02 PM
  5. Making secondaries stay open
    By PuckPuck in forum Motor Cities NECO
    Last Post: 2001-09-06, 09:29 PM
