Old 06-29-2008, 08:06 PM   #1 (permalink)
Cougar Dad's Avatar
ATF...Mercon or Mercon V ??
I am getting the trany flushed in my daughters Cougar this week. (99 ATX)
I bought a case of Castrol Muti-Vehicle Tranny fluid and when I got home I noticed it said on the bottles for 1983 - 1996 Ford vehicles.
Her owners manual and dipstick both only say Mercon. The 1983 - 1996 is what is throwing me off. Sooo... am I good with what I have? And what is the difference between the Mercon and the Mercon V?
Cougar Dad is offline
Old 06-29-2008, 08:11 PM   #2 (permalink)
11 days
Re: ATF...Mercon or Mercon V ??
the car came with mercon III. If you are taking it to a shop to do they should have the correct stuff.
this should cover your questions
BUY COUGARFEST RAFFLE TICKETS
jaged is online now
Old 06-29-2008, 09:40 PM   #3 (permalink)
deliveryguy's Avatar
I always thought *engine flushes were a gimmick...usually unnecessary if you've maintained oil/filters.
WTB
•99-00 Fog Lamps •Aussie Corner Reflectors (01-02) •99-00 Wheel Cap
deliveryguy is offline
Old 06-29-2008, 09:46 PM   #4 (permalink)
11 days
so as long as you change your oil filter do you not have to change the oil? besides the trans doesnt have a filter, and if it did would you want 190k on trans fluid like i do? and the trans has its own fluid separate from the engine oil
jaged is online now
Old 06-29-2008, 09:56 PM   #5 (permalink)
I think drain and fills are different than flushes...this is based off an article I read that was geared towards engine flushes. I saw "flush" and my brain said "gimmick"...I should start thinking a little eh?
WTB
Old 06-30-2008, 04:24 PM   #6 (permalink)
yup thinking is always a good thing.
now your right, there are 2 types, the mercron III/Dex?? something mix which is what was filled from the factory and Mercron V which is quite a bit more expensive. Ford actually discontinued manufacturing the Mercron III and released a service bullitin to migrate over the V stuff.
I'm still hesitant to put the Mercron V in....
