Closed Thread
Old 04-29-2008, 07:15 AM   #1 (permalink)
is 14.4 mpg normal for my 99 cougar?
I live in NY and i mainly drive on freeways and expressways. Also i currently have an o2 sensor problem that my mechanic at the dealer can not fix after 4 tries
miguel11691 is offline
Old 04-29-2008, 07:20 AM   #2 (permalink)
has too many projects
Re: is 14.4 mpg normal for my 99 cougar?
on the hwy unless you are in stop and go traffic you should be getting 25mpg or better. i would get the sensor fixed, or at least reset the code
BUY COUGARFEST RAFFLE TICKETS
jaged is offline
Old 04-29-2008, 07:22 AM   #3 (permalink)
freednighthawk's Avatar
No, 14.4 is not normal. And if your mechanic can't fix an O2 sesor problem, than it might be time to find a new mechanic.
Is the car running really rich? Like you can smell gas from the tail pipe?
Bone stock 99 Rio Red ATX Cougar... Bet you havent seen one of these before :P
Mostly Stock Charcoal Metalic 89 S10 Blazer
freednighthawk is offline
Old 04-29-2008, 08:14 AM   #4 (permalink)
BUYER BEWARE
kustomcougar's Avatar
how many miles are you getting to the tank? cause i know when i had an 02 sensor go out i got like 140 to the tank, but i got it fixed really quick
2.5 MTX/Roush/ Flowmaster/ SVT/ Aussies/ Konig Unknows
WTB: 01-02 black leather seats
WTB:01-02 SHIFT KNOB
Originally Posted by Sean2124 View Post
MY 2000 Cougar Stock Got Beat By a HYandai accent TODAy PLEase tell me how to make my car faster?
kustomcougar is offline
Old 04-29-2008, 08:41 AM   #5 (permalink)
And you forgot to meantion if you have the Duratec (V6) or Zetec (I4). I'm gonna guess the Duratec, just because I can't imagine the Zetec only getting 14mpg even with a bad O2 sesor.
Old 04-29-2008, 09:27 AM   #6 (permalink)
stock > ghetto
B3NN3TT's Avatar
Images: 51
Also note - the dashboard readout is NOT accurate if it has been recently reset. It needs 2 or 3 tanks to stabilize, or the number changes too drastically.
Reset your trip odometer at each fillup. Divide the miles per tank by how much gas you just filled up with in order to get an ACCURATE measurement of fuel economy.
In addition - make sure your tires are inflated properly, and that you have healthy spark plugs and spark plug wires. Make sure your air filter is clean, and your fuel filter has been changed within the past... oh... 2 years or so.
And go easy on the throttle
Andy- Ohio NECO's "Green Guy"
Denied by foliage
B3NN3TT is offline
Old 04-29-2008, 09:43 AM   #7 (permalink)
I gotz da gold!
branchedout's Avatar
im sorry for your troubles, but this thread made me smile in a perverse way, because I thought at roughly 19mpg i had close to the worst gas mileage on here, lol.
Lost Racer : I don't do siblings...unless they're both female
Bdiddy : i love freshman. i get older, and they stay the same age. haha!
CougarGrrl99 : my sauce is yummy
308.50/219.4/199
branchedout is offline
Old 04-29-2008, 10:23 AM   #8 (permalink)
Yea it is a 2.5. I just bought the car a month ago.and warrenty expired. How much do I think it will take to fix
Old 04-29-2008, 11:30 AM   #9 (permalink)
One Eye Blind..No really
Depends on the actual issue. What exactly is the issue with your O2? Are you throwing a code? If so what code? Is the right sensor being changed out? Did the sensor get changed out or just an attempted cleaning?...
The One&Only!
C.A.R.B # FU50
LostRacer is offline
Old 04-29-2008, 12:24 PM   #10 (permalink)
Designated_Drifter's Avatar
besides the physical calculations, (spark plugs, air filters, o2 sensors) alot of the mpg you get are reflected on the way you drive. If you baby your car and ease on the gas then you will get significantly longer distances out of one tank of gas, rather than just slamming on the peddal. You dont have to floor it to get up to speed, it took me awile to get used to not hammering down on the pedal casue i had a dodge neon with absolutely no acceleration and was nearly rear ended on every freeway. My solution, fix that sensor, check your air filter, spark plugs, etc. and if your still not getting higher mpgs, then you might wana have the car looked at cause theres definatly a major problem then. I get around 19-20 mpg average. I drive about half the time in town as on the highway and floor the gas about half the time so it weighs even.
~ 99 Mercury Cougar ATX ~
Designated_Drifter is offline
Closed Thread
