Old 04-26-2008, 01:00 AM   #11 (permalink)
It's bad for ya!
Tygerr's Avatar
Re: Reimbursement from Ford for fuel pump replacement on returnless Cougar?
Good news to hear. I called once to a Ford dealer and they told me my 02 was not covered, a few years ago.
So BBF, all cougars are covered under failure of the fuel pump?
Hopefully you're friend get's all his money back.
Buckeye @ heart
06 Legacy 2.5i Limited
Tygerr is online now
Old 04-26-2008, 10:18 AM   #12 (permalink)
Hi Tygerr. No, not all Cougars. According to the non-compliance letter which Ford filed with NHTSA on 8/26/04, only Cougars manufactured between 5/25/99 and 11/30/01.
Your Dealer may be correct. Check the build date of your Cougar, located on the door jamb sticker. If your '02 was manufactured after 11/30/01 (good chance of that), your fuel pump was already the updated model.
Good luck.
2001 Cougar - 2.5L V-6 - 5 Speed MTX - Black Clearcoat - Medium Graphite Leather
2007 Lincoln MKZ - 3.5L V-6 - 6 Speed ATX - Alloy Clearcoat Metallic - Light Stone Leather with Dark Ebony Wood
BBF2530 is offline
