View Poll Results: what kind of motor oil do you use in your cougar?
Regular 27 21.43%
A blend of synthetic and regular 14 11.11%
Full synthetic 71 56.35%
My engine actually runs on magic or electricity so I don't use oil 14 11.11%
Voters: 126. You may not vote on this poll
Old 04-18-2008, 11:06 PM   #41 (permalink)
AZ Sundogs - CHL Champs!!
azbobbybooshay10's Avatar
Images: 7
Re: what kind of oil do you use?
Originally Posted by GTownCougar View Post
My owners manual says to use ATF
Also, 2001+ Ford and Hondas reccomend 5w-20 for all vehicles I believe
Ford screwed up. Check the link in my post, thats the TSB (Technical Service Bulletin) for Ford dealerships. Be careful, I've had dealerships try to tell me to use ATF even after the TSB has been issued.
And yes, 01-02's are 5W-20 (although I haven't heard of any problems using 5W-30 in an 01-02).
And I'm still running the stock 2.5.
2008 Australian V8 Supercar Standings (After Bigpond 400 @ Barbagello Raceway, Round 4 of 14)
1. Garth Tander - Holden Racing Team Holden Commodore VE.............896
2. Rick Kelly - HSV Dealer Team Holden Commodore VE.....................882
3. Mark Winterbottom - Ford Performance Racing Ford Falcon..............872
Next Round: Midas 400 @ Sandown Raceway - June 7-9
1999 Mercury Cougar V6 MTX - "Sonic" SCCA DSP #85
azbobbybooshay10 is offline
Old 04-18-2008, 11:11 PM   #42 (permalink)
GTownCougar's Avatar
Always nice to know that Ford messed up on something that important. And the 5w-30 is fine to run in the engine, probably better actually, but the 5w-20 gives improved gas mileage.
~2001 Cougar 2.0 MTX~
~Aussie Headlights
GTownCougar is offline
Old 04-19-2008, 12:01 AM   #43 (permalink)
spider1178's Avatar
Images: 2
5W-30 Royal Purple with Mobil 1 or K&N filters every 4-5K miles. 95,000 and don't use any oil between changes.
'99 Cougar ATX V6 silver frost
spider1178 is offline
Old 04-19-2008, 10:45 AM   #44 (permalink)
Defying gravity...
LinkMan's Avatar
Images: 11
Actually, the 99-00 are also now recommended 5w-20, the recommendation is backwards compatible. And there is no problem with 5w-30 in either model year range. I've used both - Motorcraft 5w-20 semi-synth during warranty period, and Mobil 1 5w-30 since then.
Mark (AIM:LaserRedCat)
When I'm in my car, I look good. CF 2005 Best Stock - CF 2006 Best Paint (tie) / 2nd Cleanest - CF 2007 Cleanest Cougar
1998 T.Red Contour V6 ATX FCO
1993 Bright Red Tempo 2.3 ATX
LinkMan is offline
Old 05-06-2008, 08:51 PM   #45 (permalink)
Full synthetic, change every 5k mi. or so
giants_0023 is offline
Old 05-08-2008, 02:24 AM   #46 (permalink)
El Mucho Post Whoro
Gold MemberAdministrator
NorCalCoug's Avatar
I use the slippery kind.
NorCalCoug is offline
SEO by vBSEO 3.1.0
