| General Info General questions and comments relating to the Cougar that don't fit into other categories. |
| View Poll Results: what kind of motor oil do you use in your cougar? | |||
| Regular |
27 | 21.43% |
| A blend of synthetic and regular |
14 | 11.11% |
| Full synthetic |
71 | 56.35% |
| My engine actually runs on magic or electricity so I don't use oil |
14 | 11.11% |
| Voters: 126. You may not vote on this poll | |||
#21 (permalink) |
AZ Sundogs - CHL Champs!!
Re: what kind of oil do you use?
Royal Purple 5W-30 with Motorcraft FL-820S filter here. For the record, I switched to synthetic at 125k miles (not sure what oil was ran in it by previous owner), and never really had much of a leak. The valve cover gaskets and oil pan gaskets had a slight leak afterwards, but IDK if that had anything to do with the synthetic oil. I replaced them when I had the engine and trans out last winter and haven't had a problem since.
2008 Australian V8 Supercar Standings (After Bigpond 400 @ Barbagello Raceway, Round 4 of 14) 1. Garth Tander - Holden Racing Team Holden Commodore VE.............896 2. Rick Kelly - HSV Dealer Team Holden Commodore VE.....................882 3. Mark Winterbottom - Ford Performance Racing Ford Falcon..............872 Next Round: Midas 400 @ Sandown Raceway - June 7-9 1999 Mercury Cougar V6 MTX - "Sonic" SCCA DSP #85 ![]() |
#22 (permalink) |
switch from reg to synthetic.. "previous owner's choice i guess" 130k to wat it is now 160k. " HAD NO LEAKS ! " . Not saying that you cant.. i just didnt get any.
Car ran great to. |
#23 (permalink) |
from my understanding having leaks caused by switching to synthetic does not apply anymore. That came from when synthetic oil first came out and they didn't have enough of some adative to maintain seals, etc ...
if it starts leaking then there was already a leak there ... my SeVT and my SVT will get mobil 1 with a FL-300 and FL-820S resepectively and I run about 5k on the oil change. this works about to about one or two oil changes per year based on the miles I drive with the cars. the Mystqiue gets regular Castrol GTX 10w-40 and a FL-300 at about 4k per change. I did use the Valvoline high milage oil for awhile and it slowed a number of small leaks but then all of the sudden they got worse so I stopped using it.
#24 (permalink) |
My leaks could have been caused by the fact that I did dump some seafoam in the oil the day before I changed it... The oil came out lookin' NASTY...
I'm actualy getting due for another oil change on the Blazer, and the wrench turned on in the Cougar as well... Looks like as soon as I get some more money I'm gonna be doing some oil changes.
Bone stock 99 Rio Red ATX Cougar... Bet you havent seen one of these before :P Mostly Stock Charcoal Metalic 89 S10 Blazer |
#28 (permalink) |
Was that sposed 2 happen?
I use regular Pennzoil SAE 5w-30 and a Fram or Mobile One oil filter. 114,000 miles on the car, never had a problem of any kind. I just change the oil and filter regularly.
- WTB front struts, springs/coilovers, 19mm rear sway bar, front sway bar links, inner/outer tie rod ends - headers, and black or gunmetal gray wheels - Roush floormats, wheels, pedals, and spoiler
- For Sale: Venom 400 Performance Control Module - Kaminari Wing - Stock Throttle Body - Misc. engine parts - 1999 Mercury Cougar V6 MTX - Kaminari/Roush/SVT ![]() |
#29 (permalink) |
Calendar Lady
I switched to synthetic last year, and actually have noticed I need to top off my oil less than before (mine doesn't leak, but seems to burn/evaporate about a 2qts between changes). I am guessing the synthetic is more resistant than conventional oils.
CougarDB CarDomain TeamNECO garage MySpace
NECO Northwest come buy some NECO goodies ![]() CLICK to purchase a 2008 NECO Calendar ![]() |
