#37281 (permalink) |
11 days
Re: The Undead Gateway Thread
it almost takes 2 people to check for spark. pull one plug and put it back inthe wire. push it against something that is grounded and it should spark when cranked.
check the big three plugs on the passenger side, its easy for one of them to slide loose, and i would double check the crank sensor. that wont let it fire if its not fully plugged in
#37284 (permalink) |
hmm, will check the crank sensor.
and great, I had no idea how to check for spark, will try that tonight.
#37286 (permalink) |
olympian + swedish....
need I continue. + crossbow + nudity. ya, its like that SVERIGE AR NUMMER ETT - What Would Tyler Durden Do [page is actually sfw, clicking on the photos however is not]
#37287 (permalink) |
and the germans are raising the bar with a kayaker
DEUTSCHLAND IST NUMMER EINS - What Would Tyler Durden Do [same rules apply]
#37288 (permalink) |
^ deserving of the sailboat tag.
I know someone here that would appreciate the woodworking craftsmanship.
#37289 (permalink) |
yes, very nice 'sailboat'
"Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you." --Anonymous *Done with School* |
