#35431 (permalink) | |
I hear voices...
Re: The Undead Gateway Thread
I make sure it is securely on the jack/jack stand, squat down next to the wheel, grab the back side of the wheel securely and lunge backward. A bit of warning though as I've ended up laying on back back with the wheel on my chest on multiple occasions. Then before you put the wheels back on, put a thin layer of antisieze on the hubs to prevent the wheel from sticking in the future.
#35432 (permalink) | |
I hear voices...
So, I stopped by the Bentley/Maserati dealership because I noticed they were putting up a new building. Unfortunantly, it isn't the Alfa showroom that I was hoping it would be. Instead it is a Lambo show room and Bugatti service center.
#35433 (permalink) |
EFFING MOSQUITOS
did that tom, did it for 20 min. i sprayed a layer of wd 40 around it to hope that it soaks in and ill give it a shot tomorrow. even used the notches on the back of it to try and get a prybar in there.
#35434 (permalink) | |
I hear voices...
The only other thing I can think of is to lower the car down onto the wheel and see if the weight of the car pops it loose (obviously don't remove the jack completely).
#35435 (permalink) |
i used a sledge hammer on the back of the tire, but i also did it while on a lift
"Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you." --Anonymous *Done with School* |
#35438 (permalink) |
nice, you know there is also plastic faced mallets that are a bit more durable and still soft enough
#35439 (permalink) |
Is moving.
![]() Join Date: Aug 2004
i prefer facing away from the car and giving it the good old donkey back and forth on different sides of the tire.
In wine there is wisdom, in beer there is freedom, in water there is bacteria. -Ben Franklin |
#35440 (permalink) |
EFFING MOSQUITOS
ground controls are installed. had to use the rubber hammer to beat on the back of the rim to get it to come off.
so i had some noise coming from the front of the atx that sounded like a wheel bearing. checked the bearing and its all good. but where the axle goes into the trans has some play up and down and about 1/8" in and out ![]() and terry how close is your exhaust to your subframe connector on the drivers side? i need to do something to keep it from banging up against it
