Thread: The Undead Gateway Thread
  1. #31961
    is watching you. Lifetime Platinum MemberModerator sonza68's Avatar
    Jan 2001
    Right behind you
    12,608
    Re: The Undead Gateway Thread
    Brake fluid decided it wants to escape from where the brake hose screws into the caliper. Everything had been fine, and then as I was waiting to start my second run, I noticed the pedal was really soft, but they seemed to work fine during the run. When I went to check tire pressures I noticed brake fluid everywhere on the driver's front wheelwell. Jacked it up took the wheel off and sure enough, it is was leaking from that spot. Packed it up, drove home using the brakes as little as possible and now I need to figure out why it started leaking.
    Hopefully it is as easy as tightening it up, but I'm not terribly hopeful about that. Although it does raise a question, is there some kind of sealant I should have used on that joint when I replaced the caliper last spring?
    Show me who to smite and they shall be smoten.
  2. #31962
    NECO Member Terec's Avatar
    Mar 2006
    STL
    3,172
    did you forget the brass washers required for banjo bolts?
    Boobs are like a Shelby Cobra, even the fake ones are awsome.
  3. #31963
    Jan 2001
    Right behind you
    12,608
    I don't recall. That gives me something to check though.
  4. #31964
    Mar 2006
    STL
    3,172
    yup, i had the same problem with a fuel fitting on the mr2, forgot the brass washer on one side
  5. #31965
    Lost in Oz Moderator Moraki's Avatar
    Aug 2004
    8,121
    hummmm i dont remember any brass washers when i did my calipers... and whats a banjo bolt? /confused.
  6. #31966
    Mar 2006
    STL
    3,172
    banjo fittings are a common fitting often found where flow has to take a 90 degree turn into or out of an object, usually a small fitting that works on fuel lines(stock cars) and hydraulic lines(brakes, clutch, ect)
  7. #31967
    Jan 2001
    Right behind you
    12,608
    I missed the banjo bolt part of your previous post. We don't have those on the Cougars. Just a straight fitting that screws into the caliper.
  8. #31968
    3L Roush 'S' Platinum MemberModerator MaverickFlyer's Avatar
    Aug 2004
    Aurora, Ontario
    20,406
    I broke the bolt that holds the rear sway bar. Not a big deal I've broken rusted bolts before. I drill it and insert a bolt extractor. Guess what, I broke that to. So now I'm screwed. I'm going to have to take out the sub frame and cut apart the nice boxed mounts and redo them.
    Any other suggestions???
    3L 99 Rio Red MTX , Nummelin Motorsport Group
    91 306 Dech Coupe, 08 Escape, 96 Contour, 01 Yamaha R6
    Official Member of Ontario NECO, and MC-NECO
    PROUD MEMBER OF THE ND4SPD ARMY
    www.roadawareness.ca
  9. #31969
    Moderator Moderator J-Man's Avatar
    Jun 2004
    IOWA
    12,245
    Sounds like your only option. It's not hard to drop it, and I'm assuming you've done it before so it should only take you a half hour to get the thing out of there.
    '01 DSG
  10. #31970
    Aug 2004
    Aurora, Ontario
    20,406
    Quote Originally Posted by J-Man View Post
    As long as I don't break any more rusted bolts.
    I'm really considering storing my car for the winter. Only problem is I already have two cars in storage I don't have room for a third.
  1. Replies: 42
    Last Post: 06-02-2010, 09:55 AM
  2. Gateway Website
    By whiteboy477 in forum Gateway NECO
    Last Post: 05-04-2006, 07:40 PM
  3. The Undead Gateway Thread
    By 1slosvt in forum Gateway NECO
    Last Post: 03-24-2006, 07:29 AM
  4. The Undead Gateway Thread
    By sonza68 in forum Gateway NECO
    Last Post: 03-24-2006, 02:19 AM
SEO by vBSEO
