Old 11-10-2006, 11:13 AM   #1 (permalink)
any idea?
I pulled the alt, and had to pull the steering arm...well, the arm didn't go back in, so I pushed it in a little to align the hole again. This morning I drove the car, the steering is way off. I have to steer right to go straight. Now, turning left, the car will turn, but sort of want to go straight to. So, I'm in a pinch, I'm suppose to leave tonight to chicago....so, I'm thinking of trying to put the wheel straight and pull the arm and adjust the wheel to straight again.
you motor boatin' son of a
slurpee is offline
Old 11-10-2006, 11:15 AM   #2 (permalink)
Is moving.
Moraki's Avatar
Re: any idea?
no clue... never had an issue like that. Is everything bolted back in place?
I guess just inspect that steering arm.... see how the other end looks .../shrug
In wine there is wisdom, in beer there is freedom, in water there is bacteria. -Ben Franklin
Moraki is offline
Old 11-10-2006, 11:25 AM   #3 (permalink)
Re: any idea?
I had that seconds before my wheel snapped off.
Old 11-10-2006, 11:27 AM   #4 (permalink)
Re: any idea?
gggrrreeaattt. was it the wheel bearing?
slurpee is offline
Old 11-10-2006, 11:29 AM   #5 (permalink)
Um...
Re: any idea?
Well, that's scary, Terry.
So you probably only had to remove one arm right? Both wheels are facing the same direction right? We don't need any wheels snapping off again...
Good luck. I just hope you don't have any major problems with it.
- Reagan
Phantom is offline
Old 11-10-2006, 11:41 AM   #6 (permalink)
I hear voices...
sonza68's Avatar
Images: 14
Re: any idea?
I'd double check it if you can and see if anything looks out of place. If you can't find the problem I've bring it somewhere to get an alignment before driving to Chicago.
sonza68 is offline
Old 11-10-2006, 11:50 AM   #7 (permalink)
Re: any idea?
that's what I was thinkin'....wonder if dobbs can do it with that short of notice.
slurpee is offline
Old 11-10-2006, 12:02 PM   #8 (permalink)
I hear voices...
sonza68's Avatar
Images: 14
Re: any idea?
They should be able to. You might try giving them a call and see what they say.
sonza68 is offline
Old 11-10-2006, 12:07 PM   #9 (permalink)
Re: any idea?
got an appointment at 3:30 today....pray that's the problem!!!
slurpee is offline
Old 11-10-2006, 12:50 PM   #10 (permalink)
Is moving.
Moraki's Avatar
Re: any idea?
Pray if thats the problem they have the part.... at 3:30 they arent going to have the time for a part run... unless your lucky.
Moraki is offline
