Cam and Crankcase Cleaning
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 30
Thread: Cam and Crankcase Cleaning
    NECO Member PzKpfw_III's Avatar
    2010 Aug
    Clifton, NJ
    1,542
    My valve covers are off for paint and I'm wondering what I should use to clean the cams and crankcase, without removing them from the car? I know Seafoam should clean some out, though while I have the opportunity I figure physically cleaning would be best. I know I won't get them perfect, but I'd hate to put the covers back on knowing the build up that's there. Does it looks like there's too much there and if I clean it all at once I'll end up knocking so many particles loose that I clog a line?
    Cam and Crankcase Cleaning-dsc_0295.jpgCam and Crankcase Cleaning-dsc_0304.jpgCam and Crankcase Cleaning-dsc_0298.jpg
    1999 Mercury Cougar Base ATX 2.5L w/post factory Convenience Package
    EPA Clean Air Section 609 Certified
    2000 Oct
    Minneapolis, MN
    7,473
    Re: Cam and Crankcase Cleaning
    That motor is a ticking time bomb looking like that. You can try to run some ATF in with your oil but if you knock any large chunks loose you could end up clocking your oil pump and blowing the motor up. Did someone forget to change the oil for 100k miles?
    Click here to see my Cougar.
    2010 Aug
    Clifton, NJ
    1,542
    I took over the car at 105k and it's at 126k now. I've changed the oil every 3k or 4k so it's not from my watch that it got like that. It's not nearly as bad as some that I've seen.
    2002 Jun
    Columbus, Ohio
    19,875
    I'd start doing 1500-mile oil changes with a really high-detergent oil.
    2010 Aug
    Clifton, NJ
    1,542
    Confused Re: Cam and Crankcase Cleaning
    Well I've cleaned out the majority of the sludge manually and with carb cleaner, though I'm still going to clean some more. I've hesitated to use synthetic because of the oil leak, but after this I think I may switch regardless. I'll post pics of what it looks like now.
    Edit: Cam and Crankcase Cleaning-dsc_0308.jpgCam and Crankcase Cleaning-dsc_0307.jpgCam and Crankcase Cleaning-dsc_0309.jpg
    How does it look to you guys now?
    NECO Member spridget's Avatar
    2005 Apr
    In a shed, doing maths
    717
    Damn, that's nasty. Now that you've cleaned up some of the major gunk, check out AutoRx. This stuff works. You may need to run 2 cycles, but it will clean your engine. I suggest you drop the oil pan, remove any gunk, and clean the pickup screen. With an engine in that condition, it is imperative that you remove the oil pan, and clean it along with the pick up screen after performing any type of cleaning (engine flush, etc).
    1999 SVT Contour 3L
    1998 SVT Contour - SOLD
    2002 Cougar Sport 3L - SOLD
    1997 Contour Sport 3L - RECYCLED
    2010 Aug
    Clifton, NJ
    1,542
    Yeah i was thinking of dropping the pan after this. I'm really disappointed in how bad a condition it was in. The previous owners must have either not changed it enough or used some real cheap stuff.
  9. #8
    2010 Aug
    Clifton, NJ
    1,542
    Is there an easier way to remove the oil pan than outlined in the Chilton manual? I'm in Utah at the moment and need to get back to NJ soon so I'm pressed for time.
  10. #9
    2005 Apr
    717
    I haven't read the Chilton manual. I suspect it tells you to remove the y-pipe. I suppose it can be done without removing the y-pipe, but a couple of the bolts are tough to access. Plus, you should probably replace the pan gasket once it's removed. The gasket tends to break at the front cover.
    1999 SVT Contour 3L
  11. #10
    2010 Aug
    Clifton, NJ
    1,542
    It wants me to remove the exhaust crossover and exhaust retaining bracket on the right side of the oil pan, remove the exhaust heat shield retaining nuts and shields from the left side of the pan, remove the oil pan retaining bolts from the trans housing, remove the access plug from the engine rear plate, remove the through bolt for the left and right front engine support insulators, remove the upper front engine support bracket nuts and remove the support bracket, raise the engine and then remove the pan bolts and ultimately the pan.
