Go Back   NECO Forums > General > Garage Talk
Garage Talk Non-Cougar automotive discussion, pictures & videos.
Old 05-12-2008, 01:56 PM   #1 (permalink)
pwhitelock's Avatar
Fuel injector rail removal help
Hi guys and girls, not been on here for quite a while so hello again!
Im fitting the SVT T/B, LIM and UIM and have already gone through a how to on this and it does not explain this bit very easily. How do i get the LIM away from the injectors and rail? Do i need to disconnect the injector rail from the fuel lines too? In the how to i am looking at it looks like you do not remove the rail from the lines but a guy on another forum (who isnt on there just now) did:
Your help is much appreicated!
Paul
2.5 V6 SVT Cougar
pwhitelock is offline
Old 05-12-2008, 02:07 PM   #2 (permalink)
Re: Fuel injector rail removal help
you need to remove one side of the bar for the secondaries throttle.
then remove the 3 bolts for the fuel rail.... then pull. first time on mine it was a bit hesitant to come out. just make sure you dont lose any of the o-rings for the injectors.
