(this is a copy of my CL ad) im in Des moines ia
i have a 2000 cougar v6 auto with 144,000 miles its black primer paint on it. its the sports package so there is 16inch rims,leather seats,speed Governor removed and all 4 disk breaks. . runs good and drives well tranny is in good shape, motor as well, no leaks or anything, been driving it to albia from des moines every weekend the body is in kinda bad shape and has a crack windshield and the passage side door needs a new handle and top hinge. but the inners are good besides its making a weird sound in the back of the car when you go over bumps but i replaced the struts and struts mounts last summer
i have title in hand and ready to go (its a salvage title)
it also needs a new Key as it broke in half in the ing
what i added to the car was
SVT upper intake
SVT Throttle body and bracket
Short ram intake
SVT #19 injectors (not installed)
new Alternator put in last summer from auto zone with life time war
new Struts and strut mounts on all 4 sides
new wheel bearings and ball joints and tie rods last summer
break pads and rotors on all 4 sides 2 summers ago
Custom Exhaust from Cat back with magnaflow muffler
2002 dash cluster (white)
new ABS computer
new EGR
new DPEE sensor
new belts
this would be a good parts car or a fixer upper i gave it oil changes every 3 months and its about time for one, does need a alignment pretty bad and def needs some new front and rear tires, the motor has 2 CELS on and one is a for a O2 sensor and the other is for a temp sensor (which i have on hand) the ABS light is on because the front ABS speed sensor was ripped out on the driver front tire and its 30$ at a junk yard and pretty easy to put on, other then that it drives really well and has not broke down since a year ago (because of the alternator which i put a brand new one in)
idk how to add pics but here is my CL add and it has the pics
LinkBack URL
About LinkBacks
