Closed Thread
Results 1 to 4 of 4
Thread: FS: Koni Struts w/ Ground Control Coilovers = $900 shipped!
    be trollin fer trolls Lifetime Platinum MemberAdministrator FastCougar's Avatar
    Nov 1999
    Kearneysville, West Virginia
    8,409
    Cool FS: Koni Struts w/ Ground Control Coilovers = $900 shipped!
    Everything you need for a perfect suspension setup with very low miles (less than 2K miles) on the setup. Below is an image capture from today of a shox.com configuration for a 99+ Cougar and as you can see, this setup will cost $1,089 + S&H. Not to mention, the perches will need to be removed and the struts assemble with your existing top mounts. This setup not only saves you money, but a lot of time and headaches AND comes with extra goodies.
    As you can tell, from this pic, these where done right ... lathe turned to remove the perch.
    Fronts ready to install ...
    Rears ready to install (including top mount bolts)
    Extras included:
    Koni adjustment knob (hard plastic), custom billet knob (CEG group buy) for rear in-car adjustment (requires removing rear strut tower covering), spare bearings for top mounts.
    Notes: Everything pictured has 2K miles on it ... the top mounts where even purchased new!
    Price: shipped = $900, pickup = $850
    Former owner of a 1999 Mercury Cougar - Turbo'd 3L.
    For Sale: 17" Kazera KZU w/Avon Tech M550 A/S 225/45ZR17 tires - $700 + Shipping
  2. #2
    NECO Member Nezerconezer's Avatar
    Apr 2008
    Phx, AZ
    198
    Re: FS: Koni Struts w/ Ground Control Coilovers = $900 shipped!
    These will work on a contour too correct?
    Dual Weilding SVTC
    2000 Silver Frost/Midnight Blue 564/2150
    2000 Toreador Red/Prairie Tan 576/2150 Project Tour De Force
  3. #3
    Nov 1999
    8,409
    Yes, these will also work on the Contour/Mystique
  4. #4
    Nov 1999
    8,409
    Sold to JScullin
Closed Thread
  1. Gc coilovers and koni struts
    By Dbatzos in forum Suspension Performance
    Last Post: 09-28-2009, 03:47 PM
  2. Used Koni Yellows w/ Ground Control Coilovers
    By XRTONY in forum NorCal NECO
    Last Post: 08-12-2009, 01:24 AM
  3. FS: 1999-2000 Koni Struts & Ground Control
    By FastCougar in forum FS: Automotive Parts & Accessories
    Last Post: 05-30-2006, 12:39 PM
  4. GC Coilovers and Koni Struts
    By C2Cougar in forum Keystone NECO
    Last Post: 09-01-2003, 11:52 PM
  5. Koni adjustable struts and Ground control coil overs.
    By CougarEVO11 in forum Suspension Performance
    Last Post: 07-10-2001, 03:05 PM
SEO by vBSEO
