Go Back   NECO Forums > Important Info > Forum Issues
Forum Issues Have an idea for / problem with the forums? Post here!
Old 05-25-2007, 02:42 AM   #1 (permalink)
See you @ CougarFest 2008
Lifetime Platinum MemberGold Member
gulfcat's Avatar
Logged out quickly if not constantly refreshing
When I'm logged into the forums, and composing a post or message, I sometimes get logged out before I get done. Yes, I'm a slow composer, but it seems to me that it's about 10 minutes without loading a new page or doing a refresh that gets me kicked out (and sometimes my composition lost!)
I looked in User CP & didn't see anything to set for length of inactivity....
Odd thing is that CEG's forum doesn't kick me out nearly as quickly... and it looks like the same setup.
I use mostly Firefox, sometimes Opera, seldom IE, but it seems to happen in all of them.
Any suggestions? (My current fix is have a second tab open & refresh it every so often... but if I'm focused on what I'm typing I forget, and then I'm logged out.)
Peggy Says: Cougar Den Mother!
'99 White 2.5L MTX, CougarDB
gulfcat is offline
Old 05-25-2007, 03:14 AM   #2 (permalink)
Images: 743
Re: Logged out quickly if not constantly refreshing
Check the "remember me" box when you login and all will be fine.
Old 05-25-2007, 03:20 AM   #3 (permalink)
gulfcat's Avatar
Thanks!
gulfcat is offline
Old 05-29-2007, 09:56 AM   #4 (permalink)
Cockblocking since 2004
frenchblueC2's Avatar
I've had that happen to me on CEG too when I don't click the remember me box.
That should definitely fix your problem.
Kim
2001 Cougar C2
2007 Mazdaspeed6 GT
frenchblueC2 is offline
