Fuel Pressure drops
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Like Tree1Likes
Thread: Fuel Pressure drops
    NECO Member Beans's Avatar
    2007 Feb
    871
    Fuel Pressure drops
    Gentle creatures of the 2 doors,
    Current setup. Return fuel system. Stock 2.5L Rail. Stock Regulator. 42lb injectors. Walbro 255lph GSS342 (Fuel pump has been insane loud since day one very whiny outside of the car. )
    My fuel pressure is dropping at WOT at roughly 5.5k~ RPM or greater. From 60~ PSI down to about 40 (Maybe less) Causing the car to lean out, basically have no choice but to let off....
    - Regulator and rail have maybe 2k miles on them, fuel pump has maybe a few hundred miles on it. Running a stock style sock. New fuel filter. Gas tank is full.
    - I have a fuel pump jumper relay to run fatter 12ga power direct from the battery.
    - voltage is good all the way through the rpm.
    I don't know what the hell is going on.
    E1 '99 SVT Contour Solds
    E0 '98 SVT Contour Portmatched 3L w/ Soopercharger
    Mazdaspeed3 GT w/understeer
    2007 Feb
    871
    Re: Fuel Pressure drops
    Dyno. Note RPM and A/F when i run out of fuel .
    2007 Feb
    871
    Found this DanG post from back in the day. It's pretty much exactly my symptoms, except for my pressure doesn't go down to 20psi... Maybe 40psi before i let off.
    Fuel Pressure Drop @ WOT...
    Add your 2 cents plz
  5. Remove Advertisements
  6. #4
    NECO Member andreyyyk's Avatar
    2010 Mar
    spokane washington
    4,482
    What kinda fpr u running?
  7. #5
    2007 Feb
    871
    Quote Originally Posted by Beans View Post
    Stock Regulator
  8. #6
    2010 Mar
    spokane washington
    4,482
    oops, missed that. well the walbros have a tendency of going out alot. id start there. flow test it or something maybe
    1999 Mercury Cougar MTX. Full 3.0L. 232whp. 241tq
    1990 S13 Hatch. 2JZ 3.0L drift project
    2004 A4 Quattro 3.0L. New Daily
    2006 GSX600R. white and blue pearl sold
  9. #7
    2007 Feb
    871
    I ordered a 340 aeromotive. How would i bench test it? It's a tough test being high rpm high load.
  10. #8
    2010 Mar
    spokane washington
    4,482
    that i dont know. i know some pumps are just volume tested for like 15 seconds or so. of its not within spec toss it. not sure if walbro has any specs online
  11. #9
    2007 Feb
    871
    Fixed. Fuel Pump, as i thought.
    Walbro = junk
    LostRacer likes this.
  12. #10
    NECO Member Gold Member gamiller's Avatar
    2001 Jun
    Dulles, VA
    3,014
    Walbro = junk
    I recall reading a few years ago that "Walbro" pumps from China had flooded the market. They had all the same markings as the real McCoy. It's going to kill Walbro's reputation. You may have seen in the news that a similar issue is plaguing Amazon. Orders from legitimate businesses are being fulfilled by Amazon with Chinese knock-offs; everything that looks the same is treated the same at the warehouse. That practice is eventually going to catch up with them and kill their rep.
