Zetec Turbo
Page 1 of 35 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 10 of 343
Thread: Zetec Turbo
    NECO Member c0alition's Avatar
    2007 Jun
    Amherst, MA
    942
    Zetec Turbo
    Finally actually have enough parts to start work on my turbo setup. I figured I'd start a thread, and update it with pics and details as I go along.
    I bought a wastegate adapter and got an adapter plate made to mount it to my stock exhaust manifold. I'll be doing all the piping to the driver side of the car; that should help me avoid all the mess on the passenger side. I took out my AC dryer to make room for the turbo to feed the bottom pipe of the intercooler.. I'll be mounting up the intercooler and piping out intake side this weekend.
    Those who say it cannot be done should not interrupt those who are doing it.
    Quote Originally Posted by aboythatskates View Post
    your stupid.
    be trollin fer trolls Lifetime Platinum MemberAdministrator FastCougar's Avatar
    1999 Nov
    Kearneysville, WV
    8,487
    Re: Zetec Turbo
    One piece of advice ... create some brackets to help support all that weight. The stock header studs where sized to support the weight of the stock header/catalytic converter only.
    Former owner of a 1999 Mercury Cougar - Turbo'd 3L "Mavro Gato".
    For Sale: Turbo Cut Heads (w/SVT cams), All New Timing Equipment - PRICES SLASHED!
    1% Moderator iceberg65's Avatar
    2007 Apr
    Medicine Hat, AB
    2,894
    Re: Zetec Turbo
    looks like a promising build. I would defiantly be talking to turbozetectour, I'm sure his knowledge will be a valuable asset in your build.
    The ONLY Supercharged Zetec Cougar!
    NECO Member fordrule's Avatar
    2002 Dec
    Fort Campbell, Ky
    6,128
    Re: Zetec Turbo
    Quote Originally Posted by iceberg65 View Post
    looks like a promising build. I would defiantly be talking to turbozetectour, i'm sure his knowledge will be a valuable asset in your build.
    +1
    OLD RIDE: 2000 Roush Cougar Clone 3L HMS trans..many extras...SOLD...in good hands with Bluestreak..... dis be my car-domain page cardomain
    CURRENT RIDES: 1965 Ford Mustang Cpe / Whimbleton White/ 200cid 6cyl /\ 1994 Mustang GT
    2007 Jun
    Amherst, MA
    942
    Re: Zetec Turbo
    ooh, didn't even think about the weight part! I'll definately look into brackets.
    BTW, welded intercooler brackets and mounted it up... might have to lift it up a little bit. I tested a few different ways of piping.. and I'll have to do a little bit more modding to make everything fit right. I cut out an area to fit a pipe through the stock air hole into the fender.. but the piping just seems to be too stressed and confined in the area.. and i don't want it rubbing or even breaking/cracking if I hit a bump wrong.
    your stupid.
    NECO Member 99cougarOZ's Avatar
    2009 Jan
    Tennessee
    223
    Re: Zetec Turbo
    how much was it for everything in the 1st picture on the start of the thread?
    2007 Jun
    Amherst, MA
    942
    Re: Zetec Turbo
    I'm not sure.. about $1200. The turbo is just a cheap dummy turbo to get setup.
    your stupid.
  9. #8
    TZT Performance Gold MemberModerator Turbo Zetec Tour's Avatar
    2007 Sep
    Louisville, Kentucky
    3,118
    Re: Zetec Turbo
    I dont know if the Cougars have it or not but i know the pre98 Zetecs and all Foci have a bracket that comes off the axle bearing bracket to help support the exhaust which is why i didnt have problems with the weight. if your car doesnt have the bracket, then just fab up a bracket that goes from one of the turbo housing bolts to one of the old CAT support strap bolts.
    if you have the AC removed completely, i suggest removing the condensor and mounting the intercooler behind the bumper support, the farther back you can get it the better as it will mean more clearance with the bumper.
    Daniel - TZT Performance
    2000 Black SVTC #391 - sold
  10. #9
    2007 Jun
    Amherst, MA
    942
    Re: Zetec Turbo
    yea, took out the condenser today. Depending on how this piping works out, I may try that route. I guess it didn't really look at it much.. but is there really enough room to mount a 3" deep intercooler?
    your stupid.
  11. #10
    2007 Jun
    Amherst, MA
    942
    Re: Zetec Turbo
    yea looked at it today.. intercooler won't fit in place of the condenser. but I finally found a piping that I like and the bumper fit back on. I had to cut out the "fog light cover bracket"?? I don't know what to call it.. but after that the bumper fit fine.
    your stupid.
  1. Zetec Turbo kit development- need Zetec Cougar!
    By NKTasty in forum 2.0L ZETEC Performance
    Last Post: 2010-06-20, 02:17 PM
  2. Turbo 2.0l Zetec VS Turbo 3.0l Duratec
    By LV99NEC in forum Forced Induction
    Last Post: 2009-01-08, 07:33 AM
  3. 2.0l Zetec Turbo
    By JohnS'01 in forum Forced Induction
    Last Post: 2008-02-01, 09:03 PM
  4. to those of you with a turbo zetec
    By james99 in forum Forced Induction
    Last Post: 2005-08-23, 11:31 PM
  5. Turbo Zetec Cougar
    By APTCSVT in forum Forced Induction
    Last Post: 2001-08-22, 05:11 PM
