Drive axle strength
Not sure if this is the place to ask this. But im budgeting to get a 3l and 3lduratec.com supercharger kit and was wondering if the drive axles are strong enough to support all the added power from the supercharger on slicks and a stage 3 clutch again not sure if i was supposed to post this here or the transmission section
99 DT 2.5L MTX- Custom Cold Air Intake, Custom 2.25in Exhaust, Painted Headlights, Gutted Pre-cats...Coming soon- ZEX Wet System, 2.5" Dual Exhuast
Re: Drive axle strength
it is a drag track and its well set up i mean i hook up well on street tires and the little mods i've got dropping at about 2500 im worried the with the new parts that im planning on installing and the slicks that the axles won't be able to handle at that torque also is there any way i can get stronger axles as a safety net
It's all about how you drive the thing. I had cheapy Advance Auto reman halfshafts in my turbo 3L for 2 years before I sold it- Nary a problem. Then again, I didn't go slamming gears or drag launching. Smooth engagement of the power is fine, even if it's putting over 400hp out of the crank. But the first time you shock the drivetrain, the weakest link is going to start degrading, eventually leading to failure.
You'll definitely need a LSD before the axles break. Look into a Torsen or a Quaife. The axles will be the next to go. I'd bring a trailer if you plan to run slicks.
OK just to add my 1p/1cent worth lol
i was having the same worry when i was modding my car with the 3l now the problem i had was my drive shafts/axles needed to be shortened now the ones i had made are good for 600bhp so thay say and cost £700/$1300 not cheep but the biggest problems not-the shaft it was always going to be the drive joint/CV joint so I'm assuming that will be the weakest link for you to ......... hope that helps
Actually when the axles snap it normally isn't the joint. A few have posted up pictures of the axles snapping right at the spline leaving the end of the axle stuck in the transmission. I don't believe anyone has had a joint issue.
Joint faillure is usually only high hp/tq applications. Your correct as the splines is usually where failure occurs.
Barack the c*nt hunter 402whp 379 ft lb. 1999 3l turbo cougar 1998.5 Sh*tVT contour #3162 |
#10 (permalink) |
okay. iv broken 13 half shafts. i have put my u joint into about 8 pieces and had the worst vibration imaginable goin on. id say prolly 5 of my axles were due to joint failure if not more. but this last one was the funnest id say.
oops - CEG Forums
2002 cougar MURDERED OUT GRIP SKANK ![]() well this list is a bit long http://www.cardomain.com/id/CougarGuy0218 http://www.myspace.com/scubasteve1987 |
