#11 (permalink) |
Re: Turbo peices, hotside and cold side
You going to got 2.5" down? also when do you plan on starting this project? i want a turbo im my car come spring wheather its ur kit if its worthy
or a nautilus kitWhat size of cold pipes 2.5 as well? and are you going to include the intake side of the turbo the filter n all? Are you going to fab up brackets to the pipes in certian locations cause there is many places that need it..Cause im seriously interested in this if i can spend the $1400 or less if you will go without the intercooler cause like i said i got one and i would just buy my self a turbo and BOV and 44mm WG...I am good friends with a guy out of edmonton that owns AFIperformance so he would dyno n tune my car ![]() |
#12 (permalink) |
3'' down pipe
2.5 turbo to IC, i think im going to do 3'' IC to TB not sure yet. well the only problem is i dont know if it will fit with your FMIC... because i dont plan to run much larger than 6-8'' tall
99' turbo zx2- in pieces in the storage unit 91' dodge stealth RT/TT slowly building 00' SVTcontour- old DD now getting turbo'd 96' f-350 quad cab dually 7.3L turbo diesel |
#13 (permalink) |
...Is there gonna be enough exhaust pressure for the 3" down? considering this isnt going to be wildly boosted what 8-13psi? 2.5" is more than enough. just putting some past discusted points in
Hight wouldnt matter but what kind of lenght r u looking at? To make things easier i would just buy the kit with the FMIC that you offer and mod it where i have to, to make it work with my FMIC no biggi And do 3" from filter to turbo inlet ![]() Last edited by sheldon729; 12-26-2007 at 09:38 PM. |
#15 (permalink) |
Considering it would be a completely different setup with practically no parts in common, yeah, I'm pretty sure there would be.
Click. Read. Be awed by my awesomeness. And enjoy! MEMBER OF THE NECO LIB CREW! 2002 Lincoln LS - daily driver/chick magnet ![]() 1999 Mercury Cougar - Terry sums it up best . . . |
#16 (permalink) | |
1999 Mercury Cougar - Turbo'd 3L. Status: Car on hold ... preparing for baby #2 Power: 391.9 hp @ 6750 rpm | 374.2 lbs/ft. @ 4250 rpm | boost @ 11 psi For Sale: 19" Konig Verdicts with Toyo ProxesFZ4 225/35ZR19 Tires - $850 shipped! "Physical slavery requires people to be housed and fed. Economic slavery requires people to feed and house themselves." - Zeitgeist: Addendum |
#17 (permalink) |
TiAL 44 v-band
This is the WG you should make the kit fit None of that gasket bolt up **** that will leaktial-hw-wg44wpair_m.jpg |
#18 (permalink) |
its fine, just dont come across like i dont know what im doing...
![]() what erk'd me was your statement of i have a long way to come, when not knowing much about what ive done ect..
#19 (permalink) |
So are you going to do this cause i would buy a hot/cold pipe set-up...Next question is the finishes of the piping would the cold be polished and the hot coater or what?
#20 (permalink) |
it will come bare, all the hot side stuff will be stainless.
the charge pipes(cold pipes) will be semi-polished, but i dont have the equipment to polish them, the will lose their shine when around the weld. im working on this currently to turbo my contour, so as soon as im done and i like how it fits. give me a month or so....also time depends on how my buddy wants to do this when he gets money so i can also use his cougar as well.
