| Notices |
#31 (permalink) |
Re: I can look at this all day
looks good man. I used the same color on mine. Once the weather breaks we'll have to get together and go show off along the water, once I get this oil issue resolved. Did you fire that puppy up yet? I'd like to find out if you're having the same problems with the gapless top rings... give me a shout. I plan to start working on the car again real soon. Joey is hounding me to get everything put together.
Justin
Custom Millennium Body Kit, Preditor Hood, Z3 fenders, CC Short Throw Trubendz SS Dual Exit w/Magnaflow, Built 3.0L, NPG Stage 3 kit |
#33 (permalink) |
That right there is the newb quote of the year!
![]() ![]() ![]() No, he doesn't know unless he has access to an engine dyno, which is MUCH more expensive than a chassis dyno. He won't know until he get in the car, works out the tuning bugs and then gets it on the dyno. See my sig for possibilities ... keep in mind, I have a cooling issue and at the time had a boost controller issue (since solved) ... I'm now able to slip the clutch at will by simply pushing the boost past 14 psi ![]()
1999 Mercury Cougar - Turbo'd 3L. Status: Just hit 22.1 psi @ 60% duty cycle on boost controller. Power: 391.9 hp @ 6750 rpm | 374.2 lbs/ft. @ 4250 rpm | boost @ 11 psi For Sale: 19" Konig Verdicts with Toyo ProxesFZ4 225/35ZR19 Tires - $900 shipped! "There are times when I wish someone would implement facepunching over TCP/IP" - NorCalCoug |
#34 (permalink) |
Hi Puck Puck; great job. I'm looking at the hot pipe and thinking would it be possible to put the front header on the rear and the rear on the front. The reason would be to shorten the pipework under the motor...what do you think ? ..g.
2.5L MTX. SVT ECU. 2 Cold air feeds. Hogged out MAF. 65mm P+P TB. Port matched SVT upper to SVT LIM. MSDS Headers. Optimized Y pipe. Test pipe. Wish list. 4X4 wtb aussie endlinks with poly bushes |
#36 (permalink) | |
#37 (permalink) |
Reminds me of mine from '03... (Except ADC kit with liquid intercooler and not nearly as color coordinated
#38 (permalink) |
...is that front header probe/mazda or custom ? Hey you really have to go some to think of something new around here eh
G.
#39 (permalink) |
The ADC kit was so expensive because it's headers where made as part of the kit and they where 321 SS IIRC, not 304.
#40 (permalink) |
someone call a medvac
any update on the build pierre?
