Old 01-13-2008, 07:37 AM   #21 (permalink)
bigboostingfocus's Avatar
Re: I can look at this all day
that's ****ing awesome...
For those of you that said I was complete retard, the deepest corner in the abyss of hell is reserved for your noncaring souls
bigboostingfocus is offline
Old 01-13-2008, 09:06 AM   #22 (permalink)
AndyMan's Avatar
AndyMan is offline
Old 01-13-2008, 10:12 PM   #23 (permalink)
T3/T4 60-1
PuckPuck's Avatar
turbo blanket was just purchased, hopefully that's the last piece of the puzzle.. I'm sure I'll need some funky clamp, bolt or some odd fitting here or there, but that should be the last of all the major products.
One day I'll actually put together a list of every single part going into this setup... trust me when I say I'll need an afternoon to type it up.
PuckPuck.Com
PuckPuck is offline
Old 01-14-2008, 12:51 PM   #24 (permalink)
3L Roush 'S'
Gold MemberModerator
MaverickFlyer's Avatar
Damm you Pierre, I'm trying so hard to not mod the Cougar this year! You're not making it easy on me.
Looks great, can't wait to see it at the track!
MaverickFlyer is offline
Old 01-14-2008, 03:46 PM   #25 (permalink)
5% Nation of
only 352 more days to go.
1996 Contour SE MTX loaded w/ 134592
1999 Silver Frost ATX original owner w/ 70049 [in storage]
"why buy it when you can build it for twice the price??!?!"
Contour by day, Cougar by night.
Old 01-14-2008, 04:30 PM   #26 (permalink)
cougarpimp916's Avatar
that looks amazing. i just wish i had the cash to put a turbo on my car. (showing my v6 cougar ignorance here but...) is there a particular reason, like clearance or something, why the front header/exhaust goes to the passenger side, the pulls a 180 to go to the turbo? seems like it would flow better to go straight to the turbo instead of making those crazy bends. just curious.
2002 black 2.0L mtx
proud to b the "runt" of ohio
cougarpimp916 is offline
Old 01-14-2008, 05:10 PM   #27 (permalink)
Images: 732
4 words: Front Engine Roll Restrictor
That and the header already bends ... doing this would require modifying Marty's headers, which is easily done, but more work and makes for a much lower front clearance.
Status: Just hit 22.1 psi @ 60% duty cycle on boost controller.
For Sale: 19" Konig Verdicts with Toyo ProxesFZ4 225/35ZR19 Tires - $900 shipped!
Old 01-14-2008, 06:09 PM   #28 (permalink)
someone call a medvac
Images: 2
your making me want a kit more and more
Old 01-14-2008, 06:21 PM   #29 (permalink)
Originally Posted by PuckPuck View Post
The headers are ceramic coated, then wrapped. the car will only see rain if i get stuck in it, and will never see cold weather. I'm not worried about the wrap ruining the headers. Running the hp I plan on running, the headers will last longer than the engine.
I originally bought 100ft of header wrap. However the ebay guy sent me 2 100ft packages instead of 2 50ft packages. So I ended up with an extra 100ft, which allowed me to wrap the entire y-pipe/up-pipe, down-pipe and the split-pipe running under the trans.
Are you also painting the wrap? At least Thermo-Tec recommends their paint over the wrap to better seal it.
Hi-Heat Coating
To finish off a clean and well-protected Exhaust Insulating Wrap application it is recommended to use the Hi-Heat Coating.
The coating will protect the wrap from abrasion and harmful liquid spills. Extra resins and binders toughen the surface, extend the life of wrap by protecting it from friction, and seal the pores to minimize the penetration of harmful liquids.
The coating also works excellent as a paint directy on metal surfaces.
Thermo-Tec: Hi-Heat Coating
morbid
2000 Contour SVT (black)
morbid is offline
Old 01-21-2008, 09:58 AM   #30 (permalink)
T3/T4 60-1
PuckPuck's Avatar
I've thought about it, but DanG has had a horrible experience with it. The Seal is really if you plan on driving your car in weather, and that is something I do not plan on doing. With the little traction I'm going to have to start with, rain isn't going to make driving any fun.
PuckPuck.Com
PuckPuck is offline
