super charger
I want to put a supercharger on my 2.5v6 cougar but have been told that this will pressurise the crankcase is this correct
is there anything i can do to fit a supercharger, is it possible what alternatives are there:? |
Correct > Quick
Re: super charger
Yes, you can fit a supercharger.
Read, learn, gather some cash. Interest in Supercharger setup There are also available turbo kits. See the forced induction forum a couple below this one ![]()
Re: super charger
The link below is to the kit I developed. I'm currently looking for buyers willing to help me work on pulley sizing for the 2.5L. Check out the supercharger tab on my web site:
3L Duratec As far as your question about crank case pressure that will not be a problem in my kit or any kit that has been designed correctly. If the valve cover breather tubes were hooked up to the intake piping than this would cause that issue. In my kit the breathers are vented via a small filter because it is a blow through setup. If it was a suck through setup you should hook the valve cover breather lines in before the supercharger/turbo but after the MAF. If you are interested or have questions you can PM me.
Karma just kicked ass
Re: super charger
Hi....try posting in Blackcoog's thread about his supercharger if you had specific questions about it, instead of asking them in this random thread.
I told you that when I deleted your thread, which you should be able to read as the reason I deleted it. Now that you've felt the need to clutter this one up yet again, not taking the hint from last time, I'll extend you a special invitation to go the thread in the FI section that Blackcoog started. Click here: Interest in Supercharger setup Do you need someone to hold your hand??????? ![]() |
