Forced Induction Timing/fuel/tuning
Please do not respond to this thread unless you have hands on experience.
What are the base/max timing degrees for 2.5L duratecs?
What have other forced induction duratecs ran for base timing.
Has anyone locked their timing in so it cannot be advanced or retarded by the computer?
The reason for the q's is I finally ran at the track and am looking to start tuning and data logging. Wanting to compare what timing im showing with someone else on the board.
Thanks,
Lar
99 MTX-Vortech S/C-Quife LSD-Unorthadox Clutch/Flywheel-Roush newstyle Wheels-Toyo Proxies T1s-MSD DIS4-Jackson Water Injection-SCT Custom Programing-APEXi RevSpeed-Autometer Boost, A/F, Fuel Pressure and Oil pressure Gauges-Poly Motor Mounts-Trunk Mounted OPTIMA Red Top-Borla Catback Single Outlet-Ford Racing wires-NGK plugs-PIAA fog lights-Roush Springs-Turboxs Diverter Valve-B&M Shifter-PLX wideband and converter
