#71 (permalink) | |
boosting on side-streets is still quite a rush. i wouldn't say there's a lot of torque steer, but i'm wary of the reduction in reaction time available. i'd say the boost is quite usable, although right now it's not coming on strong until 4000 RPM. i think that's likely due to an exhaust leak i developed.
#73 (permalink) |
back in the states
where are the pics Gary? you promised pics........
joey ![]() ![]()
#74 (permalink) | |
well, my cat must be female, because i haven't noticed any swelling under the hood! seriously, though, I'll look for a swelling next time. a mechanic warned me that the composite upper would not handle more than 14 psi or so. anyone with forced induction had a problem with this yet?Driving around town today, I found two more things to tweak. First, my A/C has been rendered useless by the air-to-air intercooler. Hopefully the Fall will usher in cooler temperatures here in Hot-lanta. I wonder if there's some way to help the A/C be more effective. Anybody? Secondly, my dash buzzes whenever my engine is hard at work. I think I can reduce such vibrations by firming up my roll restrictors (a.k.a. motor mounts), which are currently stock. I took a trip out to McMaster-Carr to pick up "solid" urethane that should cure in under two hours and withstand 9000 psi. I hope 85D is not too harsh. Pole120 from the CEG used 94A "flexible" urethane. So, my To Do List now contains a mere seven items: * Replace MAF and capture data * Remove, fill, and reinstall roll restrictors * Install Nautilus rear brake kit * Install wideband oxygen sensor * Install gauge pod and gauges * Install aluminum pedals * Replace driver's seat leather * Replace e-brake cable Pics requested will be posted tonight.
#75 (permalink) |
94A is hard as a rock ... 85D should be a good compromise with more flex.
1999 Mercury Cougar - Turbo'd 3L. Status: Car on hold ... preparing for baby #2 Power: 391.9 hp @ 6750 rpm | 374.2 lbs/ft. @ 4250 rpm | boost @ 11 psi For Sale: 19" Konig Verdicts with Toyo ProxesFZ4 225/35ZR19 Tires - $850 shipped! "Physical slavery requires people to be housed and fed. Economic slavery requires people to feed and house themselves." - Zeitgeist: Addendum |
#76 (permalink) | ||
#77 (permalink) |
Gary,
All a matter of a simple turbo change....but you'd lose the smooth progressive onset of boost and probably deal with wheelspin like crazy. If you have a good boost controller then you can run low boost with a different turbo for the lower gears then kick it up when you hit the straights.
#78 (permalink) | |
![]() EDIT: I couldn't wait until Spring. MAF upgraded to 90mm!
#79 (permalink) | |
For faster spool we size the exhaust housing but the 60trim compressor is the best of the T3/4 series. I assume you have the .63 exhaust? That should be quite good once you start boosting to 10-12psi. You won't want any more power down low. lol
