#101 (permalink) | |
Barack the c*nt hunter 402whp 379 ft lb. 1999 3l turbo cougar 1998.5 Sh*tVT contour #3162 |
#102 (permalink) |
I hated my camber plates. They were more trouble then they were worth. Good to hear your swapping back to the stock plates. I was using mine for camber that was out of spec but I installed new lower control arms and it brought my camber back into spec with the stock top plates.
#103 (permalink) | |
#105 (permalink) |
Quick update for those wondering whatever happened to gamiller:
The car is still running rich enough to wilt the trees I pass, especially in the morning, but Joey has been good about sending me a new tune to try each week. I also leave a blue cloud behind me whenever the car is under boost. For my own sanity, I decided to check the pressure in my cylinders. It's a relatively simple test I recommend to anybody installing a used engine in your car. Anyway, I was relieved to get the following pressure readings for cylinders: 200, 205, 210, 205, 205, 220
#106 (permalink) |
those pressures are alot better then what I got from my engine ....
as for the smoke what pcv do you have installed? I was getting blue smoke after being in boost. turns out the pcv wasn't sealing and pressurizing the crank case. installed a turbo coupe pcv and it was good to go.
#107 (permalink) | |
#108 (permalink) |
valve guides
![]() Compression check should have shown lower numbers though if it was a valve guide. Perhaps it just normal blowby. Did you do your compression check with the engine fully warmed up and with the throttle body closed? If not, redo the compression check.
#109 (permalink) | |
No oil was added to the cylinders for the test. I think my CR is 9:1. From what I read, the comp test checks rings, valve seats, and head gasket. I should double check with my buddy as to whether the readings were consistent; he only reported the peak numbers to me.
#110 (permalink) |
I'm sorry, I meant wide open ... the throttle should be wide open during compression testing
