Old 07-31-2007, 10:07 AM   #1 (permalink)
BOV on a supercharger
Anyone ever heard a BOV on a supercharger? You'd only see this on a blow through setup and you'd only run a blow through setup if you had issues moving the MAF before the supercharger. Since I'm running a blow through setup I have a BOV.
Normally on a turboed car you hear it release pressure for a split second when you let off the throttle. On mine it dumps pressure at the same time but since it's a supercharger and it's being run off the belt the supercharger continues to pump so unless you are under 2k rpms it continues to hiss the entire time if you continue to decelerate without putting the clutch in. It's kind of neat but also kind of annoying if you want to drive it daily and stay someone unnoticed. My wife said it sounds like a snake. I think the sound is amplified because it's in the fender well area behind the bumper. I may pickup a bypass and run a tube down under the car so I can't hear it as well. For reference I have an Apexi dual chamber BOV.
Old 07-31-2007, 11:09 AM   #2 (permalink)
Was that sposed 2 happen?
ModCougar's Avatar
Re: BOV on a supercharger
Hmmm...that's pretty cool. I bet it would get annoying though.
- WTB: front struts, springs/coilovers, 19mm rear sway bar, inner/outer tie rod ends - headers, and black or gunmetal gray wheels - Roush floormats, wheels, pedals, and spoiler
- For Sale: '99 Headlights - Kaminari Wing - Stock Throttle Body - IACV - Misc. stock engine parts
- 1999 Mercury Cougar V6 MTX - Kaminari/Roush/SVT
ModCougar is offline
Old 07-31-2007, 11:20 AM   #3 (permalink)
PLATINUM M0DERAT0R
PREDATOR's Avatar
Hmm... weird I know what you're talking about but I've never seen anything like that before.
PLATINUM FOR LIFE
PREDATOR is online now
Old 07-31-2007, 11:25 AM   #4 (permalink)
Images: 743
Why not go with a recirculating valve? Sure, you don't get that moster BOV sound when you shift, but it would be even more of a sleeper then and it's daily driving delight.
Old 07-31-2007, 01:56 PM   #5 (permalink)
cvsmightymouse24's Avatar
Yeah i agree with trevor.....running 100% atmosphere is annoying and gets old after awhile. Put a recycling tube on and the sound will be decreased by a lot!!!
"I don't want a large Farva, I want a fricken liter of cola!!"
cvsmightymouse24 is offline
Old 07-31-2007, 02:07 PM   #6 (permalink)
I don't think you understand...there is no place to recycle the air to. Reference the pictures on my site: 3L Duratec
The air should be recycled after the filter before the supercharger, but the filter is bolted to the supercharger so that isn't an option.
Old 07-31-2007, 02:28 PM   #7 (permalink)
Images: 743
You know, I was thinking that right after my reply. Why not divert it, like a waste gate setup and run some tubing down behind the engine and out the back of the car. At least that way, the sound won't be right under the hood. The majority of the noise from a BOV comes from the shape of the exiting orifice. Relocating this orifice much farther back with some tubing will dissipate the sound considerably. Not to mention, what sound is generated is now being exhaled somewhere than in front of the driver, so it will be much less noticeable.
Old 07-31-2007, 04:58 PM   #8 (permalink)
Clutch's Avatar
This isn't related but reminded me. You can now run a wastegate on a supercharger. A magazine i subscribe to had a guy cog his supercharger for 20 something pounds and put a wastegate on the supercharger to limit the air being compressed, he reached peak hp and tq faster because the supercharger was spinning faster from the start but then doesn't rise until you adjust your wastegate/boost controller.
"you suck at photoshop"
In memory of Donnie hoyle, gone but not forgotten.
OMG i'm such an internet Douche
Clutch is offline
Old 07-31-2007, 05:10 PM   #9 (permalink)
Dom1013's Avatar
...I wouldn't see a turbocharger being any different, don't think the compressor on it stops spinning completely in between shifts either...im sure it keeps moving air also, should react the same logically when u let off the throttle but I'm sure there's gonna be some difference in the two. Second, I love the sound of boost and anything related to it, it will never get annoying to me, and if it does my system could always drown it out...
-01 ATX Cougar...131.1whp 135.59 tq
-04 Ion Redline 258whp...matching tq
Dom1013 is offline
Old 07-31-2007, 09:55 PM   #10 (permalink)
AndyMan's Avatar
..... ... i want this right now
AndyMan is offline
