Old 07-02-2007, 09:35 AM   #1 (permalink)
Front Mount Intercooler
I'm looking for a good front mount intercooler that will flow enough to support my supercharged 3L. Lets say my maximum hp need is 450whp (leaves good head room) and I'd like to have as little pressure drop as possible.
The one I have now that fits is 22" x 6" x 3" and I think that is with the end tanks. It can't be any longer but could be a few inches taller or even a little thicker. It if is taller the inlet and outlet need to be as close to the bottom as possible.
Currently the intercooler I have drops the boost from 11psi to 6psi at the intake. Obviously that is not acceptable.
Any thoughts or suggestions?
I currently have my blow off valve after the intercooler before the intake. If the intercooler is maxed out where does the extra air go that can't get through the intercooler? The compressor isn't making any surging noises from air being forced back to it which is where you'd think it would have to go. It almost sounds like I should put the BOV between the supercharger and the intercooler, but I may have a space issue trying to get it in there.
Old 07-02-2007, 09:52 AM   #2 (permalink)
Re: Front Mount Intercooler
Lots of good info on the site and they let you custom order what you want. Even ship the same day for more items.
Bell Intercoolers Air to Air Intercooler Assemblies
I called Bell intercoolers and went over my setup with one of their engineers. He said the smallest I can go is about 18"x12"x3.5" (core size). This has a 800 CFM rate which should be good for 450whp. The cost is..... $796.00
A mass produced one should be much cheaper like the one below for example (the larger of the two listed):
BoneHead Performance
(the 28" one should fit I'd have to double check)
Old 07-03-2007, 06:42 PM   #3 (permalink)
Images: 743
Check out this eBay store: Just-Intercoolers
Old 07-03-2007, 06:54 PM   #4 (permalink)
back in the states
good info
Old 07-06-2007, 03:52 PM   #5 (permalink)
TT ROADSTER
Unknown2k's Avatar
Images: 1
hmm you have a problem there thats more then the intercooler. 5 psi is alot! Is your BOV leaking, or is there a crack in the intercooler. OR a hole from a rock? I've heard of .5 to 1 psi loss when people go bigger with the intercooler, but 5???
THE OLD CAR
Unknown2k is offline
Old 07-06-2007, 06:01 PM   #6 (permalink)
Audiobahn Abuser
blustreak's Avatar
I believe the problem is that the intercooler is too small and that's why the loss is so large.
WTB: Vortech Spec MSDS Headers : Front Adjustable Koni's : Good condition Stock MTX Shift knobs : 3 gauge Pillar pod : 4 gauge Airbag pod
FS: (make offers) New WeaponR Headers & Y : COP set : Walbro 255lph fuel pump : Cougar S CF Hood : 2 Pillar gauge pod - LSB : Razzi High Rise Spoiler - Silver : 19" Icon W64's w/ Toyo Proxie4's : Misc 3L Parts : +more just ask if I have it
cougardb
Like to travel?
blustreak is offline
Old 07-07-2007, 12:34 PM   #7 (permalink)
Car holds boost fine without the intercooler. It is definately the intercooler causing the drop. I'm looking into a larger one.
Old 07-07-2007, 12:44 PM   #8 (permalink)
TT ROADSTER
Unknown2k's Avatar
Images: 1
nope Boost is boost. If the intercooler is too small then the air is to hot thats it. The reason they list a a HP limit is the total amount of air that the intercooler can cool.
The reason I say this is B/c the intercooler i have gets heat soaked in this AZ sun but I'm not losin any psi.. just power from the hot air. but if i get a bigger intercooler the air will be cooler but I wil lose a little psi b/c the amount of air needed to fill the intercooler will be more..
THE OLD CAR
Old 07-08-2007, 01:31 PM   #9 (permalink)
pgtatx's Avatar
Core efficiency is important... Both it's efficiency in ability to dissipate heat, and it's ability to flow air...
If you have 2 IC cores with the same dimensions... why does one produce a larger drop in pressure across the core than the other other one. If you look at a cross section of 2 cores... 1 being a name brand top core, and the other being an Ebay knock off, you'll see the answers.
Exterior dimensions alone will not tell you what the core will actually flow. Companies take guesstimated based on size, but reall companies actually test.
If an IC is too small or way too large (which is a common issue amongst the ricer community), you will end up with a not so fun situation.
If you have a turbo that pushes X amount of air, and then you have 5 ft of piping, and a huge core that flows XXX amount of air... you will end up woth significantly slower spool, and show a loss of pressure across the core. People think bigger is better, but that is not true...
If the turbo you have flows XXX amount of air, and you use an IC that flows X amount of air... you will be creating back pressure and significantly increasing the temp of the air. You may even see some some surging...
Find an optimally designed IC... good core and proper end tank design... and you will get the most out of the set up.
pgtatx is offline
Old 07-08-2007, 03:05 PM   #10 (permalink)
TT ROADSTER
Unknown2k's Avatar
Images: 1
Ya thats why I love seein the SRT-4 guys with there huge intercoolers and they just started to mod there cars.. turbo can't flow grea enough for that cooler.
THE OLD CAR
