| Notices |
is fully engorged.
Forced Induction Dyno plot sheets - Post yours here!
List your mods and post pictures of your sheets so people can see what's possible with what!
Edit by FastCougar: I'm taking a page out of the 2.5L & 3.0L forums by copying this post/thread here. The discussions should go to PMs or separate threads. This thread should be dyno plots & car modifications only, to keep it readable. I'm pulling all the extra posts out.
Skolenimation: Graphic Design | Modifications @ CougarDB.com | NEW! Flickr Account "You know what the chain of command is? It's the chain I go and beat you with until you realize who's in goram command here." - Jayne Cobb ![]() "In the beginning of a change, the patriot is a scarce man, and brave, and hated and scorned. When his cause succeeds, the timid join him, for then it costs nothing to be a patriot." - Mark Twain Last edited by FastCougar; 05-26-2007 at 03:51 PM. |
Re: Forced Induction Dyno plot sheets - Post yours here!
The Nautilus Stage 1 (slightly upgraded) kit was installed at about 130k on my internally stock 2.5L SVT motor
![]() Best numbers were; 262whp / 248wtq @7psi We were having issues on the dyno with with the boost controller and didnt get any numbers at 10psi. Mod List Precision Turbo (.57 / .63 AR) Front Mount Intercooler 38mm External Wastegate Turbo XS Type-H RFL BOV Multistage boost controller Injectors (#24) IIRC MSDS Headers Magnaflow resonator and mufflers Xcal2 tune Terry Haines built trans Qauife LSD Spec Stage 1 Fidanza Lightened Flywheel Ford Racing Wires NGK TR6's Koni Sport Kit Subframe Connectors Front & Rear Strut Bars *Stock TB and MAF* This is all I can think of for now. I'll update this when I dyno at 10psi with 3" exhaust. Dyno Sheet ![]()
1999 CSVT Turbo Last edited by Rawburt; 06-05-2007 at 10:27 AM. |
From my (now sold) 3L Turbo.
3L, forged internals,T3/4 60 trim .82 A/R ADC liquid intercooled turbo kit. This was at 10.5psi, (50% of boost controller maximum), and once again, the cams fall on their face short of 6k RPMs. Not before they impress, however: ![]() 342.84hp/346.78tq. Turned up the boost. Now at 70% of boost controller maximum (where we were before), gave it another shot. Had to shut down at ~4300RPMs due to some pinging (erring on the side of caution). ![]() Um yeah- So 366.28ft/lbs of torque? Jebus. I ripped out the 3L/Mazda 6 cam setup in favor of a set of SVT cams. Unfortunately, I did not get a retune and updated numbers before I sold the car to Kevin. I hope he'll post up with the new numbers. I miss that car.
![]() 285hp/241tq. This is with a stock internaled 2.5L, Vortec supercharger and simple bolt ons. My tuner said with a bigger MAF sensor I would have been over 300whp easily. See sig for mods. ![]()
![]() Created by Mrs. Badazz • Vortec Supercharger • SCT Chip • Bat Highflo Y-Pipe • • Snow Performance Water/Meth Injection • MSDS Headers • • 2.62" Pulley on Blower • SVT UIM • Yodude Exhaust... and Oh yeah, can you say Torque Steer?! Now Torsen,Spec 3+, and Fidanza equipped
![]() Join Date: Jul 2003
Not the highest run of the day (lost that one - doh! - Highest one was 348) and this run was done during one of the hottest days of the year!
![]() Mod list: Engine rebuilt New pistons, Big ends, Forged Conrods Main bearings, Oil pump, Engine balanced Heads fully ported and polished chambers CC,d 270 fast road cams Secondary throttle plates Removed ports Polished stainless steel six branch manifolds Fitted 410cc Injectors fitted Emerald ems C1 Procharger Intercooler 10.1 comp ratio 14 psi boost Gearbox rebuilt In-line fuel booster Custom made windscreen washer bottle Custom made radiator tank Uprated engine mounts
348bhp Supercharged Cougar S
Custom Vortech setup available on our site: 3L Duratec
MAF was pegged at about 5700rpm which is why we didn't go up to redline. I have a lightning MAF now which needs to be installed and then the car will be dynoed again. I should be able to squeeze another 20whp out up top once the air/fuel is dialed in. Boost: 10psi ![]() ![]() Current modifications are all listed here: http://www.cardomain.com/id/blackcoog
