Old 06-23-2008, 02:33 AM   #961 (permalink)
Images: 732
Originally Posted by gamiller View Post
You saying to stay out of boost?
No, open wastegate is a reference to how the wastegate is routed. Open = exhaust is routed to atmosphere before any mufflers and such. It's also called "Divorced" as a "Married" routing would join the wastegate to the exhaust system.
"Jesus was a community organizer. Pontius Pilate was a governor." - Anonymous
Old 06-23-2008, 02:37 AM   #962 (permalink)
Got turbine on my mind
Originally Posted by jaged View Post
for all your camera mounting needs
very nice, but dam is that course short
mmmmm, Traqmate! blurring the lines between video games and reality.
Old 06-23-2008, 08:51 AM   #963 (permalink)
VADriven Member
thats just one track of many at summit point. Its actually a HUUUUUGE venue. Main track is ny favorite.
Topik is online now
Old 06-23-2008, 01:05 PM   #964 (permalink)
Trevor,
It looks like you are running stainless piping correct? Would it help to switch over to aluminum piping? The aluminum will transfer heat better and may help with the temps.
Chris
Old 06-24-2008, 12:31 AM   #965 (permalink)
VADriven Member
anyone who would like to see some pictures of this amazing event they call hyperfest I have two links in which you will see whiplash,dado from mischief, and adrenaline crew
HyperFest 2008 by: ProjektPhoto (56k) - VAdriven.com Forums
hyperfest 08 - VAdriven.com Forums
Topik is online now
Old 06-24-2008, 01:05 AM   #966 (permalink)
wow, there was a lot going on that day! looks like a blast!
Kevin, why don't we see any videos of you driving?
Old 06-24-2008, 10:52 AM   #967 (permalink)
VADriven Member
currently car is under construction. Main reason it will not be at fest.
Topik is online now
Old 07-19-2008, 12:51 PM   #968 (permalink)
S3c70r's Avatar
Trevor,
Chris
Wouldnt ceramic coating help even more ?
3.0L Full Oval Port + SVT Cams + Clevite Rod/Main Bearings + SPEC Flywheel/Stage 3 Clutch + 225/40/18
NPG Turbo kit installation in progess...
S3c70r is offline
Old 07-19-2008, 05:41 PM   #969 (permalink)
20COUG00's Avatar
Images: 2
doesn't it cause it to be weaker tho..
Mods: MG Body Kit with Roush Side Skirts, Dual Cat-Back Exhaust, Intake, Ciggy Plug, IMRC Relocation, Tail-Light Covers, Shorty Antenna, Escape Oil Pan, Clear Side Markers, Akuza 18's with Nankang Tires, and a T-Top Sunroof
CARDOMAIN
20COUG00 is offline
Old 07-20-2008, 05:21 PM   #970 (permalink)
ryanblacksvt's Avatar
I love your setup man, then again I am kinda bias,lol Our set ups look the same from the under hood view except for location of the intake.
Ryan 1998 Black SVT Contour #3722 "Darth Vader"
2000 Silver SVT #1126 3L TURBO "Silver Surfer"
2005 Maroon Chevy Trailblazer LT
http://www.myspace.com/ryany1976
ryanblacksvt is offline
