#861 (permalink) |
nice video I guessing you have it in third gear by the MPH isn't it a biatch to keep traction above 400whp............
this in my opinion is the borderline point where people need to spend another 2k on getting the traction to the road otherwise the car is slower down low but a animal up top. Very nice Trevor more than impressed with your work you will have a happy buyer too. joey |
#862 (permalink) |
Camera mount is a sweet special effect
99 Coug V6 MTX Spruce Green SVT "Heavy" swap finshed! CSVT #1321/2150 Born on 1/6/00 213.5whp |
#863 (permalink) |
Yeah it's like the nitrous effect in Need For Speed Underground.
#864 (permalink) |
"You're captives of a civilizational system that more or less compels you to go on destroying the world in order to live." - Ishmael 2001 Cougar 2.5L MTX My old '99 MTX cougar |
#866 (permalink) |
I would say a custom set of axles, custom control arms, nice set of 15 or 16" lightweight wheels with some drag radials to ride around on everyday. And a fund set aside to buy tires 3 or 4 times a year.
99 Cougar, 02 Expedition, 06 xB, |
#867 (permalink) |
Maybe a custom set of solid aluminum mounts.
#870 (permalink) |
Check this out ... better aero would make the car more stable at high speed and add front downforce (more traction). Combine this with traction bars up front (tie subframe to LCA) and you will have a pretty good solution without having to go much wider on the tires:
nasaforums.com :: View topic - Calculated Risk's Time Trial STi
1999 Mercury Cougar - Turbo'd 3L. Status: Working on cooling issue and concerned about 150psi compression test on cylinder #5. Power: 391.9 hp @ 6750 rpm | 374.2 lbs/ft. @ 4250 rpm | boost @ 11 psi For Sale: 19" Konig Verdicts with Toyo ProxesFZ4 225/35ZR19 Tires - $850 shipped! "There are times when I wish someone would implement facepunching over TCP/IP" - NorCalCoug Last edited by FastCougar; 01-11-2008 at 12:45 AM. |
