#741 (permalink) |
Keep in mind, the boost settings I quote in the run are from memory. I will have to cross reference the videos.
Also, the tune is on the conservative side, running roughly 11.5:1 at WOT under boost pressures above 6 psi. Lean it out to 12.5:1 - 12.8:1 and I will pick up a **** load more torque & power. I'm just getting started!
#743 (permalink) |
What I have much better than that ... here is a link to the ones I have (I have 2 of them = 1 for PCV, 1 for VCB):
Custom Corvette Accessories Oil Catch Can for LS1
#744 (permalink) | |
om nom nom nom!
Excellent and those are brilliant numbers! I can't wait until you turn that boost up ![]()
6spd Bugeye #555|SM
#745 (permalink) |
Between tuning and boost control, I should be able to hit 500 hp without a problem ... I'm VERY excited about the possibilities! However, I'm disappointed about having to take the cold side piping apart in order to clean out the FMIC
#747 (permalink) |
Dyno Plots: Run 1: See video, no dyno plot. The dyno wasn't calibrated and the results where skewed WAY off. IIRC, the tech said "HOLY ****! 640hp!!" and I was like "Something's NOT right!" ![]() Run 2 ![]() Run 3 ![]() Run 4 ![]() Run 5 ![]()
1999 Mercury Cougar - Turbo'd 3L. Status: Parting out car: Engine for Sale | Trans for Sale Power: 391.9 hp @ 6750 rpm | 374.2 lbs/ft. @ 4250 rpm | boost @ 11 psi For Sale: 19" Konig Verdicts with Toyo ProxesFZ4 225/35ZR19 Tires - $700 shipped! Last edited by FastCougar; 11-14-2007 at 01:20 AM. |
#748 (permalink) |
BTW, the car goes from 45 MPH to 150 MPH in 4th gear
