Old 10-26-2007, 11:04 AM   #631 (permalink)
Images: 743
Off topic: Kevin, what is that in your Avatar? Supra???
Old 10-26-2007, 01:09 PM   #632 (permalink)
J-Man's Avatar
Turbo f-body. I already asked.
"How a politician stands on the Second Amendment tells you how he or she views you as an individual... as a trustworthy and productive citizen, or as part of an unruly crowd that needs to be lorded over, controlled, supervised, and taken care of." -- Representative Suzanna Gratia Hupp (TX)"
J-Man is offline
Old 10-26-2007, 03:04 PM   #633 (permalink)
Platinum MemberModerator
DanG's Avatar
Originally Posted by Topik View Post
man your eyes are going out old man. I never mentioned the spruce beast in my reply
Here we go with the age jokes again... Let me take my Geritol and I'll be ready with some snappy comebacks.
Dan G.
DanG is offline
Old 10-26-2007, 03:05 PM   #634 (permalink)
Images: 743
35r vs 30r same motor both .82 a/r on a Honda B18c block.
Take note ... the solid lines are a GT30R and the dotted lines are a GT35R ... both on the same engine. Both runs are at the same 24 psi. The Precision SC-61 is fairly comprable to the GT35R, so I'm confident that I can make 450+ whp without much problem
Old 10-26-2007, 04:23 PM   #635 (permalink)
Topik's Avatar
Barack the c*nt hunter
402whp
379 ft lb.
1999 3l turbo cougar
1998.5 Sh*tVT contour #3162
Topik is online now
Old 10-26-2007, 04:58 PM   #636 (permalink)
Images: 743
Well, I have managed to leave out quite a bit of information from my 3 psi runs.
1) It would hit 3psi and then quickly drop to 1.5 psi ... I have a boost leak.
2) My high RPM idle has returned.
I then remembered that when I used the LIM/Head plates sold on CEG, I forgot to use RTV between the heads and the plate
So, last night I made some gaskets out of some gasket material that I had left over from the throttlebody gasket I made. Also, to play it safe, I will make 2 new TB gaskets to sandwitch in my TB seperator plate that I have ... currently, there is only one gasket. Running NA, it sealed just fine, but I'm affraid the boost will affect this, so I will run another gasket on the other side just to be safe.
I will get pictures of the gaskets and the install when I work on the car tomorrow. Apparently, the rain will stop tomorrow and I plan on test driving the car again at 6psi (I would guess roughly 290-300 whp).
Old 10-28-2007, 09:49 AM   #637 (permalink)
Images: 743
Let's just start by saying I hit 6.53 psi yesterday
However, when it did, psi dropped almost instantly to 2-3 then back to 6, then back to 2-3 ... multiple times a second. I don't know what this fluttering could be. Is this normal pulsing for the wastegate actuation?
Old 10-28-2007, 12:28 PM   #638 (permalink)
DanG's Avatar
Boost controller malfunction or settings? IDK if you are even running a boost controller yet...
The boost controller will give auxiliary signal to the top diaphram of the wastegate- If no signal or bad signal, the wastegate will open and shut erratically.
Check for vacuum line diameter and/or leaks to the wastegate.
Dan G.
DanG is offline
Old 10-28-2007, 03:12 PM   #639 (permalink)
Images: 743
I've search for line leaks and can't find any. I secured all the ends and tugged extremely hard and couldn't get them to budge. However, it's still fluttering
I did however manage to hit 8.54 psi
Old 10-29-2007, 01:36 AM   #640 (permalink)
Images: 743
Well, I just wanted to post my spring values in case that makes a difference in helping me diagnose this issue.
Wastegate: 38mm TiAL w/ 3.63 psi spring
BOV: 50mm TiAL w/9 psi spring
EBC: AEM TruBoost
Crack pressure = 5.00
Turbo: Precision SC-61
