Old 10-16-2007, 12:44 PM   #591 (permalink)
Originally Posted by FastCougar View Post
I figured as much, but thought that it would at least build some boost
i revved mine at stoplights today on the way into work. the vacuum would go from 20 to 0 but the gauge did not read boost (8 psi) unless the car was moving and the pedal was at least halfway to the floor.
Old 10-16-2007, 01:12 PM   #592 (permalink)
Images: 743
Thanks for confirming this Gary ... I will try to get around to wiring up the gauge this week in the evenings and then finish off the exhaust next Sunday ... then it's time to play
Old 10-16-2007, 01:21 PM   #593 (permalink)
warmonger's Avatar
Oddly enough, I was home sick today
The car is running ... there are only two things to complete until I can road test it:
1) Create the cat-back exhaust system.
2) Rewire the Air/Fuel gauge & wire up the boost controller/guage.
I started the car and let it idle for 10 minutes while I triple checked everything to make sure I had no leaks and that the turbo was draining properly.
Now, I have a mechanical boost/vac. gauge that I hooked up and it only read vacuum ... even when reving to 5,000 RPMs
So, I checked the vacuum line routing and it's exactly how the boost controller diagram specifies. At a bare minimum, I should be making 4psi. So, should the car build boost when reving in neutral? I would think so, but this is my first boosted car, so I have no experience.
not necessarily...not on as big of a turbo you have.
I couldn't unless I did repeated throttle mashing and after I did it twice it would build boost on the third try or so....but not much.
My project website
warmonger is offline
Old 10-16-2007, 01:53 PM   #594 (permalink)
Topik's Avatar
wait til its tuned
Barack the c*nt hunter
402whp
379 ft lb.
1999 3l turbo cougar
1998.5 Sh*tVT contour #3162
Topik is offline
Old 10-16-2007, 03:09 PM   #595 (permalink)
Images: 743
Well, I started the car and let it idle on the last NA tune. Tom has since sent me a tune that pulls timing a bit and disables anything related to the EGR system since mine is gone. Tom said to keep pushing things in 2psi incriments until one of two things happen:
1) I reach my goal
2) I start to hear/feel pinging
If #2 happens before #1 is achieved, more timing will be pulled.
Old 10-17-2007, 12:14 AM   #596 (permalink)
Instigator's Avatar
I cant wait to see how you like it. Youll have the biggest grin while you try to fight the tq steer @ 15 lbs. Trust me I know
1999 Rio Red MTX 3L Turbocharged **Officially Retired**
2006 MazdaSpeed6
Instigator is offline
Old 10-18-2007, 03:34 PM   #597 (permalink)
Images: 743
Well, I tore apart the dash last night and mounted the new gauge. I just need to run the wiring for this and the wideband gauge and the gauges are done. I will try to finish this tonight. I will be working on the car all day Saturday. If I finish the gauges tonight, all I will have to finish now is the exhaust system. I hope to have some boosted runs under by belt by Saturday night
Old 10-18-2007, 05:30 PM   #598 (permalink)
Images: 743
Assuming I can hit this mark on the dyno without pinging, who cares to guess what the hp/tq will be at 16psi?
Old 10-18-2007, 05:54 PM   #599 (permalink)
contrapaul's Avatar
I care to guess
524whp and 498 wtq
コントラポール
明白な"失われたレーサー"をはぎ取る
NECO_Group_On_Cardomain
My_Car_On_Cardomain
IMPORTSNC_Forums
contrapaul is offline
Old 10-18-2007, 06:56 PM   #600 (permalink)
drummerboy827's Avatar
w/ the gauge reading boost during free reving..you wont see bost unless you punch the throttle sharply, and it should spike a bit then fall back down. Slowly building rpms to 5k wont do anything. I imagine your turbo is big, so chances are you wont see boost until driving.
old: 99' cougar v6 mtx
new: 2004 wrx mt, cobb stage 2-93 octane map, 3" borla exhaust, erz downpipe 13.6 @ 101mph (run on 91 octane map)
drummerboy827 is offline
