#501 (permalink) |
Has teh Ninja Gaiden
J-Man is the true official troll moderator. I'm just me...
コントラポール ![]() 明白な"失われたレーサー"をはぎ取る ![]() ![]() NECO_Group_On_Cardomain My_Car_On_Cardomain IMPORTSNC_Forums Last edited by contrapaul; 09-16-2007 at 08:47 PM. Reason: I r wrong |
#502 (permalink) |
DPMS
Or not since he was using stock hacked up manifolds that he got from Warmonger.
"America is in that awkward phase where it's too late to implement any meaningful change, and too early to start shooting." |
#503 (permalink) | |
#505 (permalink) | |
The best thing is a water to air if you want to preserve the short run and get the best of intercooling. Then there is no comparison.
#506 (permalink) |
Don't be. Your question is still valid but I will tell you there isn't much to worry about because the air is moving quite fast so with the limited surface area of just a pipe (no fins like in an intercooler) it won't pick up heat as fast, and the air gap between the headers and his pipe is probably 4" or so...plenty by engine bay standards.
Would a different route be better? Probably if there was room, so it was an acceptable compromise.
#507 (permalink) |
Well, I ran into quite a few problems this weekend. First, it turns out that I need to raise the intercooler about 1.5" because the cooler hangs below the front bumper.
I swear I measured twice ![]() Anyways, that is an easy fix. However I'm going to have a hell of time cutting anything since my band saw broke at the gear housing ... WTF! So, I go to pull out my circular chop saw and put on the metal cutting blade and I can't get off the wood cutting blade. The stop won't catch so I can wrench off the holding bolt. So, I now need to take apart the chop saw tonight and find a way to stop it from spinning so I can remove the wood blade and replace it with a metal blade. So, that's two tools down ... but wait, there's more! My belt sander's main drive gear is belt driven from the motor. The gear is plastic and the spindle is metal ... yep you guessed it ... the plastic gear stripped out on the spindle, so now I can't sand anything. So, take head ... buy only the best tools you can afford ... don't settle for cheap ****!
1999 Mercury Cougar - Turbo'd 3L. Status: Working on cooling issue and concerned about 150psi compression test on cylinder #5. Power: 391.9 hp @ 6750 rpm | 374.2 lbs/ft. @ 4250 rpm | boost @ 11 psi For Sale: 19" Konig Verdicts with Toyo ProxesFZ4 225/35ZR19 Tires - $850 shipped! "There are times when I wish someone would implement facepunching over TCP/IP" - NorCalCoug Last edited by FastCougar; 09-17-2007 at 01:23 PM. |
#508 (permalink) | |
I think you're referring to 20COUG00's question... I figured that about the speed of the air and the distance of the headers from the piping. I would assume that the natural flow of air through that area would do quite a bit to move heat away as well. EDIT- Sorry about the bad luck trevor, if you lived in Winston I'd offer to let you use our tools...
#509 (permalink) |
Header wrap helps as well since the majority of the heat will be moved through the piping instead of being radiated through it.
1999 Mercury Cougar - Turbo'd 3L. Status: Working on cooling issue and concerned about 150psi compression test on cylinder #5. Power: 391.9 hp @ 6750 rpm | 374.2 lbs/ft. @ 4250 rpm | boost @ 11 psi For Sale: 19" Konig Verdicts with Toyo ProxesFZ4 225/35ZR19 Tires - $850 shipped! "There are times when I wish someone would implement facepunching over TCP/IP" - NorCalCoug |
#510 (permalink) |
I was at the junkyard today and saw a couple other fender mounted wiper resevoirs that looked to be a better fit. I snapped a couple pics from my cell phone.
2002 4 door focus ![]() Ford Taurus ~1999 ![]()
1999 Laser Red MTX 14.509 1/4 2.265 60' 2002 3L with SVT UIM, SVT LIM no secondaries, SVT Cams, SVT TB, 24# injectors, WR Headers & y-pipe, AEM Intake, SVT Clutch, Fidanza flywheel, Clevite rod bearings, ST200 valve springs, Underdrive pulleys, Escape oil pan, DMD, Magnecor KV85 Comp Wires, Polished timing cover-valve covers-MAF-TStat, Torsen LSD, Focus shift tower & forks, RP syncromax, SVT ECU, SCT Flip Chip, B&M Shifter, OMP FSTB, Mirko RSTB, Roush RSB, Roush Floor Mats, 2.5" Trubendz |
