#461 (permalink) |
Due to cost, I'm going to attempt to fabricate my own "hard" return line from "soft" copper tubing. I just purchased a double flaring tool that also does 45 degree single flares. That and some fittings and I should be good to go. Not to mention, the soft copper tubing can be bent in place, so I can get into those hard to reach areas that are causing my line to currently slope up. Flaring tool including shipping + supplies should run me less than $60
#462 (permalink) | |
If you do your oil system routing correctly you won't have issues with blown seals on our cars.
#463 (permalink) | |
Better to use the hard line and the variety of 45* and 90* angles they provide as I've shown in my kits from years back. Honestly you could get 1/2" corrugated natural gas flex line that can be routed in any direction and use it as long as the first few inches go straight down it is not going to back up oil and it will only trap some in the bottom turn as it goes in. I However like to use the copper water line and cut-braze all the fittings together and use a 1/2" compression fitting into the side of the pan because it makes it a perfect fit and easily removable. for service.
#464 (permalink) | |
#465 (permalink) | |
#466 (permalink) |
I forgot to post pictures, but I have the Function7 restrictor nipple (all billet aluminum) ... nice piece!
#467 (permalink) |
I need to get some pictures, but I ended up removing the EGR & DPFE. I capped the rear header where it hooked up to the EGR. I also capped the UIM where the EGR connected as well. I also removed the LIM linkage for the secondaries and removed the secondary butterflies and rods. I had to redo my turbo placement by dropping it 2-3 inches further and straightening out the flange. I'm having a hell of a time fitting my 80mm MAF & filter to the compressor inlet, but the above changes have given a few needed inches and I have it all figured out now. I'm just waiting on some more supplies before I can continue.
#468 (permalink) |
Some pictures:
SVT LIM with secondaries removed. After removing the butterfly rods, I tapped the holes and bolted them shut. ![]() EGR valve removed. Also note the DPFE sensor is missing as well. ![]()
