Old 08-13-2007, 12:41 AM   #381 (permalink)
warmonger's Avatar
Originally Posted by FastCougar View Post
Tune flashed and data logged ... that has to be a record for me. WHAT A DIFFERENCE!!! Check your email.
lol yeah! You're getting better every time. First it took 6 months, then two weeks, then a week, and finally......get ready.....a couple of hours!
Seriously though you have the datalogging down now except for adding in your wideband input. Once you do that you'll be set for the dyno both NA and turbo now.
I think I tweeced a final tune after this last datalog that should wrap up all the little details including optimizing the spark curve that seems to work well for your engine and turning the adaptive learning back on. THat will allow the pcm to fine tune your fuel trims the rest of the way by itself and in a day or so you should see your best performance coming on.
Check YOUR email now for this final tune and some other information I derived from your datalogs that may help you out.
Get a new video, that last one was too slow because you were loosing major power in the top end due to it being so rich.
My project website
warmonger is offline
Old 08-13-2007, 11:08 AM   #382 (permalink)
Images: 743
Drove the Cougar to work today ... it's an odd feeling being floored on the highway in 3rd gear and running the tach past 7,500 RPM before shifting. The previous stumble is a thing of the past. My hat is off to Tom for a spectacular tune. At cruise, the A/F ratio bounced between 14.2 and 14.9. At Full throttle, the A/F ratio stayed right between 12.4 and 12.7 ... too bad I have the turbo cut heads on here ... this thing would be INSANE with more intake velocity!
There is a dyno shop about 1 mile from my office and I'm hoping to stop by at lunch time to get 3 runs in ... if they have time/space to fit me in
Old 08-13-2007, 11:37 AM   #383 (permalink)
Images: 743
NA Dyno Run Scheduled for 2:30 PM Today!
Dyno scheduled for 2:30 PM today
Anyone care to guess the HP/TQ?
Here is a list of performance oriented modifications:
Engine/Heads & Accessories:
99 Tuarus 3L block
01 Escape 3L heads
- Turbo cut P&P
- 2.5L LIM port match
99 SVT Cams
9:1 CR Diamond Racing .5mm overbore pistons
Pauter Machine Forged Rods
Clevite77 Main & Rod bearings
Underdrive & Lighweight Power Steering & Alternator Pullies
Fuel/Spark & Intake:
#42 Ford Racing Injectors
80mm Lightning MAF
70mm Throttle Body
MAX Honed UIM
Stock 8mm Ford Spark Plug Wires
Autolite Double Plats
Transmission (built by Terry Haines):
Eurospec Focus transmission with 3.82 FDR
Torsen T2 Diff
Keyed Tower Mod
Coated Gearset (slick shift option)
Gears keyed to shaft (custom done to ensure gears don't get "spun")
Old 08-13-2007, 11:44 AM   #384 (permalink)
Is this being dynoed without the turbo kit you built? Just with what's listed above?
Old 08-13-2007, 11:51 AM   #385 (permalink)
Images: 743
That is correct ... no turbo. This will be the "before" dyno run
Considering the low compression and lack of intake velocity, I will be VERY happy with 190 whp & 170 wtq.
Edited mods listing ... forgot to add the SVT cams
Old 08-13-2007, 12:27 PM   #386 (permalink)
StealthyWeasel's Avatar
My guess:
183 FWHP, 168 FWTQ
StealthyWeasel is offline
Old 08-13-2007, 12:29 PM   #387 (permalink)
By the way, where are you getting dyno'd.. mind if I come along?
Old 08-13-2007, 12:49 PM   #388 (permalink)
Images: 743
Curry's Automotive behind AOL in Ashburn ... about 1 mile from my office. You in NOVA or at home in MD?
Old 08-13-2007, 01:10 PM   #389 (permalink)
I'm at home @ 20871.
Old 08-13-2007, 01:18 PM   #390 (permalink)
Images: 743
Here is their address: Dulles/Sterling, VA Auto Repair & Service @ Curry's Auto Service of Virginia
