Old 09-08-2006, 02:27 AM   #21 (permalink)
3L Power
mond12345's Avatar
Images: 13
Nice job so far. I used the same paint but i used the Dupli-Color® High Heat Paint with Ceramic which is good to 1200. I used silver on the timing cover and oil pan too, than a red block.
Heavily Modded
mond12345 is offline
Old 09-08-2006, 02:34 AM   #22 (permalink)
Images: 732
Originally Posted by Danef150
Nice work any high def pics of what was done to the crank ?
Thanks
Jameson
No I don't ... DanG and I had the same thing done at the same machine shop ... exact same internals except my pistons are .5:1 CR less ... Dan has 9.5:1 and I have 9.0:1. I think Dan has some pictures floating around these boards of his setup.
FastCougar is online now
Old 09-10-2006, 07:31 PM   #23 (permalink)
Images: 732
Productive weekend:
Cleaned the LIM ... it sparkels now
Installed the timing wheel ... notice the keyway is furthest from the missing tooth in the timing wheel.
Installed the crank shaft oil seal in the timing cover, installed the cover and then the oil pan.
Turned her right side up again ... note the idler pulley retaining cap & bolt are both painted silver now.
I goofed up ... I should have trimmed these "ears" off before getting everying together, but at least with everything together, the aluminum shavings will not be able to contaminate the engine.
cleaned all the bolts and installed the valve covers ... it's starting to look like an engine now!
closeup of the painted retainer & bolt holding on the idler pulley
Removed the "ears" that are in the way of fitting the alternator bracket, painted and installed the alternator bracket and the passenger's side CV joint jack shaft bracket.
Installed the oil dipstick tube ... note the "before" condition of the oil cooler.
Installed the coolant pipe that connects the heads and houses the sensors and also installed the PCV tube to the oil seperator.
Closeup of the offending "ear" that must be removed so that the oil cooler lines can pass unobstructed.
Disassembled and stripped the oil seperator assembly of it's paint and then repainted it with the silver engine enamel. I'm VERY pleased with the results! The process was VERY time consuming!
Closeup of where the offending "ear" was removed ... again, very time consuming process involving a hack saw and an angle grinder
Installed a new alternator from AutoZone (with limited lifetime warranty).
Installed the LIM gaskets and LIM.
Removed the alternator pulley in favor of my underdriven one. The process is much simpler than you would imagine ... an old serpentine belt, some locking plyers and an impact wrench is all it takes.
Old 09-10-2006, 08:04 PM   #24 (permalink)
DPMS
Gold MemberModerator
J-Man's Avatar
Pretty nice lookin build Trevor, all those painted parts are awesome. Excellent attention to detail.
"America is in that awkward phase where it's too late to implement any meaningful change, and too early to start shooting."
J-Man is offline
Old 09-10-2006, 09:58 PM   #25 (permalink)
5% Nation of
you know what, I tried the high heat dupli-color for a few parts, dont like it, it hasnt held up nearly as well as the parts I did with high temp rustolium.
anyways, the build looks great!
Old 09-10-2006, 10:17 PM   #26 (permalink)
DanG's Avatar
You're making my installs look shoddy there, dude...
Nice work!
Dan G.
DanG is offline
Old 09-10-2006, 10:37 PM   #27 (permalink)
Images: 732
Nice work!
Yeah, but it's MUCH more time consuming and costly ... so far I have gone through 2 cans of engine enamel and I'm currently on can #3, 2 cans of carb/choke cleaner, 2 cans of brake cleaner & 1 can of paint thinner (bolt bath).
Anywho, here is a nice picture of the timing cover, complete with the under driven power steering pump & alternator pulleys.
After the engine is broken in naturally aspirated, I need to pull the oil pan in order to drill & tap the oil pan for the oil return line for the turbo. I was going to tap the block like I did before on the other 3L that was in the Contour that I rolled, but had already started to build up the engine and installed the oil pan ... it was too late when I realized my mistake. Well, it's not really too late ... I guess I could always rotate the engine a bit and remove the oil pan & windage tray to tap the block ... hmmmm ... decisions decisions!
Old 09-10-2006, 11:11 PM   #28 (permalink)
Images: 732
I'm hesitant to fit my DMD to the engine now due to problems dropping the engine in. IIRC, Dan, you had a problem with SVTPete's hybrid install because the DMD was too big. Question is ... how do your properly install a DMD AFTER fitting into the chassis ... you can't get the additional 90 degree turn on the bolt with the car inches off the ground ... so, what do I do?
Old 09-11-2006, 12:25 AM   #29 (permalink)
3L Power
mond12345's Avatar
Images: 13
I don't get how everyone is saying that. I dropped my 3L in without even coming close the the DMD or that side even. I would install it! I did have a total of three people though, one to operate the engine hoist than me and yosilver442 to position the thing.
Heavily Modded
Old 09-11-2006, 01:03 AM   #30 (permalink)
Images: 732
I got three people to: Me, Myself & I
