Old 12-19-2006, 05:03 AM   #221 (permalink)
back in the states
GO FOR IT TREVOR...rock on.....finish it before fest
this is how i ran mine. i still also have not install the circuit breaker from the front to the rear...i need to it also stops the constant removing the battery terminals from the battery. just pop the circuit breaker and the battery is disconnected
Old 12-19-2006, 10:29 AM   #222 (permalink)
T3/T4 60-1
PuckPuck's Avatar
Originally Posted by Livinsvt
Here is a link. Read down a little. Some draw up to 500amps!
http://www.powermastermotorsports.com/faq-starter.html
it's on the internet so it must be right...
i'm also curious what type of tool you used to test a 500 amp load at 12.5 volts... by my calculations that's 6250 watts
you know thoses car battery charger/starters you can buy at auto parts stores... you can start a car with no battery using one of them... notice how when you slide it into the "start" position it says 75 amps right next to it... ever wonder why?
PuckPuck.Com
PuckPuck is offline
Old 12-20-2006, 02:22 AM   #223 (permalink)
Images: 743
I got an order of silicone couplers, more ss clamps, some ss exhaust hangers, tons of 3" ss tubing, an intercooler (something MUCH different) and a manual boost controller (looking for simple and dependable to start off with) on the way ... all should be here just after Christmas ... no more updates until then.
Old 12-20-2006, 02:26 AM   #224 (permalink)
Higurashi no Naku Koro ni
LostRacer's Avatar
can't wait!
The One&Only!
C.A.R.B # FU50
LostRacer is offline
Old 12-20-2006, 06:46 AM   #225 (permalink)
back in the states
your cruel, but awesome way to build suspense of the ult sleeper
Old 12-20-2006, 11:21 AM   #226 (permalink)
T3/T4 60-1
PuckPuck's Avatar
what's so different about the intercooler?
PuckPuck.Com
PuckPuck is offline
Old 12-20-2006, 11:48 AM   #227 (permalink)
Images: 743
You will just have to wait and see
Old 12-20-2006, 12:21 PM   #228 (permalink)
my solar boat sucked 72000watts in drag configuration [36v @ 2000amps].
and yes with the chargers, the "start" will say 75amps, but thats not the cold cranking amps... theres a difference
Old 12-20-2006, 12:24 PM   #229 (permalink)
Images: 743
Talk of the battery is really a moot point. Tom ran a 100 amp circuit breaker for over a year and it didn't trip during starting the car ... enough said on this subject.
Old 12-20-2006, 08:28 PM   #230 (permalink)
warmonger's Avatar
You tested this? I never said Contours drew 500, but some cars do. The newer the car the more likely it is to draw more. Some new Cadillacs draw 500 amps. We've tested this at work! Some with trunk mounted batteries as well, and none of them have a fuse or a link. That was my main point. There isn't a fuse large enough.
Yeah, on our cars I have and on most imports. Cadillac... who knows.
My project website
warmonger is offline
