Old 11-17-2006, 01:09 PM   #141 (permalink)
Clutch's Avatar
i'm losing the egr in my mustang. Is that not a possibility here?
"If anyone disagrees with anything I say, I am quite prepared not only to retract it, but also to deny under oath that I ever said it." --T. Lehrer
Clutch is offline
Old 11-17-2006, 01:15 PM   #142 (permalink)
Images: 732
No, for the same reason that I'm keeping the A/C ... I'm planning on selling the car in the future and if someone from Northern Virginia buys the car, they will need to get it emissions inspected and will fail without an EGR present if the inspector decides to pop the hood.
Old 11-17-2006, 01:42 PM   #143 (permalink)
ilovemycar's Avatar
You can leave the EGR Valve and everything hooked up on the manifold, and just delete it in the tune. Pinch it off on the end where it connects to the headers, and all will be good. As long as they don't do an all out full inspection.
I have the EGR deleted in my tune, and the car runs perfectly fine. It still "appears" to be connected tho
99 Cougar, 02 Expedition, 06 xB,
ilovemycar is offline
Old 11-17-2006, 01:47 PM   #144 (permalink)
ilovemycar's Avatar
Ps Trevor...when do you think the turbo kit will be available? 3 months...6 months...a year?
Old 11-17-2006, 02:40 PM   #145 (permalink)
Images: 732
I hope to have it done and installed by January and will then investigate reproduction of my one-off in a "kit" form.
Old 11-17-2006, 11:14 PM   #146 (permalink)
Cougar Lover, Goat Raper!
nadthomas's Avatar
I know its kind of off topic, but I was just looking at the pics of your engine and trans again and it reminded me of an idea I had the last time I had to replace my alternator. While the engine is out why not machine the alternator bracket so that the bolts go in from the passenger side. This would make the alternator bolt removal a breeze, of course a hole will need to be drilled in the wheel well to get access to the top bolt but I think it would be well worth it.
2004 5.7L M6 Black GTO
nadthomas is offline
Old 11-18-2006, 05:33 PM   #147 (permalink)
Images: 732
Here she is, ready to drop in:
Before I can do that, I needed to help out a friend and ship off my knuckles to Stazi as a "core return" since I couldn't do his suspension swap last weekend due to rain. So, I'm pretty much dead in the water without knuckles until I do his suspension overhaul and grab his ... more time to work on cleaning/organizing the garage and to work on the turbo kit piping.
Here is the result of today's work:
Driver's side before cleaning:
Driver's side after cleaning:
Passenger's side before cleaning:
Passenger's side after cleaning:
Sorry, no before shots of the engine bay ... let's just say it was filthy!!! Here are the after shots.
Next up is to clean the garage and get prepared to start fabrication of the kit. After such a long break from welding, I'm really looking forward to it.
Old 11-18-2006, 08:19 PM   #148 (permalink)
warmonger's Avatar
Also, they where based on the stock header end points so that my "kit" will be a direct bolt-on without requiring you to replace the stock headers. If you so choose, you will make much more power, but not a requirement. This will allow just about anyone to install my turbo kit by themselves in their driveway with little to no help in a full work day.
Yeah but I take it you have made a compromise on the front bank direction? The front still has the bend turning away from the open space where a turbo might be easier to fit. This leads me to believe you are going to go around to the back of the engine, combine banks, then come under the engine up to where you mount the turbo.
If so it should work fine but ground clearance will be as much of a problem as the ADC kit had. Oh well, you can't win 'em all. Power should still be pretty good I think and it will definitely be easier for someone to install.
My project website
warmonger is offline
Old 12-08-2006, 01:12 PM   #149 (permalink)
Images: 732
Just a quick update: I have everything I need to finish up the project, I just need to find the time. The engine is fully assembled and ready to drop in, I just need to find the time to do so. About the only thing left to do is rearrange the crap in my garage to allow me to install it since all my spare parts/engines/used oil needs to be moved to the other side. I'm going to try and do this on Saturday/Sunday, time and weather permitting.
Old 12-10-2006, 07:24 PM   #150 (permalink)
DPMS/Glock
Gold MemberModerator
J-Man's Avatar
So. . .how'd things go this weekend?
"America is in that awkward phase where it's too late to implement any meaningful change, and too early to start shooting."
"Gun owners for Obama!" makes as much sense as saying "Jews for Hitler!"
McCain/Palin 2008!
J-Man is offline
