Old 11-15-2006, 11:47 AM   #121 (permalink)
Images: 732
Well, I picked up two more cans of this gloss black engine enamel on my way to work this morning ... I had to return the primer since I wasn't sure how the 500 degree enamel would interact with the primer, I didn't use it. I'm also not sure how it will act with the clear coat, so I'm going to forgo that step for the time being. The idea is to let the engine heat "bake" the enamel for a few days/weeks, then I might pull it and clear coat it if needed. However, there is definitely a high gloss to the paint and I'm not sure if it needs a clear coat or it the type of paint that it is will react weird with a clear coat on it (yellow the clear coat prematurely).
Old 11-15-2006, 12:03 PM   #122 (permalink)
T3/T4 60-1
PuckPuck's Avatar
Put the intake manifold in the oven at 200* for a 8 hours... the paint will be very well baked in.
HOWEVER you should clear coat before you bake in paint, or the clear won't adhere properly...
PuckPuck.Com
PuckPuck is offline
Old 11-15-2006, 05:25 PM   #123 (permalink)
Images: 732
Well according to the maker of the paint ... Dupli-Color, I have an "application window" of 1 hour. If I must re-coat after this 1 hour window, they recommend you wait a full 7 days. Will this "bake in" method of 8 hrs @ 200 degrees circumvent this window? I have to admit, it does look really good except for a few very small areas that can be worked out later. So, right now, I plan on installing it and calling it a day. A few weeks from now during/after brake in, I will sand down the problem areas and re-coat as it will be past the 7 day period they specify (unless the bake in method circumvents the waiting period).
This is due to the fact that it's an enamel and if you re-coat outside this 1 hour window of application, the paint will tend to "wrinkle".
Old 11-16-2006, 12:03 AM   #124 (permalink)
Images: 732
Update ... UIM installed along with fuel rail injector harness ... damn shame the EGR valve is soo ugly!
Old 11-16-2006, 12:43 AM   #125 (permalink)
DPMS/Glock
Gold MemberModerator
J-Man's Avatar
Lookin good Trevor. Are those your custom made headers?
"America is in that awkward phase where it's too late to implement any meaningful change, and too early to start shooting."
"Gun owners for Obama!" makes as much sense as saying "Jews for Hitler!"
McCain/Palin 2008!
J-Man is offline
Old 11-16-2006, 10:51 AM   #126 (permalink)
Images: 732
Yes they are ... 16ga 304 SS. I then painted them and wrapped them myself.
Old 11-16-2006, 10:56 AM   #127 (permalink)
EFFING MOSQUITOS
Looks great. I wish i had the patience to do my motor like that.
why not sand and paint the egr as well?
BUY COUGARFEST RAFFLE TICKETS
jaged is online now
Old 11-16-2006, 11:05 AM   #128 (permalink)
Images: 732
The more I look at it, the more I think I will. Although it's time consuming and is setting me back from developing the turbo kit, these are things that are extremely difficult and more time consuming to remove once in the car and attend to later.
Old 11-16-2006, 11:29 AM   #129 (permalink)
You custom made those headers? They look just like MSDS or WR headers. Is there any difference?
Old 11-16-2006, 12:18 PM   #130 (permalink)
The bends leading to the collector on the front header look different than the msds setup
PErformance mods:GMK CAI, Msds headers, Level ten shift kit, TRUE dual exhaust system...no cats...flowmaster 40 series mufflers.
Future mods: Level ten Shiftronic kit, 3l with svt cams and thomas knight(or hopefully Blackcoog) supercharger with all the goodies.
shadowfox28 is offline
