#991 (permalink) | |
#992 (permalink) |
No problem. I hope moving your IACV feed solves your issue. First time I've heard anyone report IACV failure, but that might also be due to the fact that you are running higher pressures than everyone but Joey.
EDIT: Say, have you moved your DPFE/EGR from the header to the down pipe? Guys at CEG are reporting that the DPFE cannot handle the pressure or the heat of the exhaust gas.
#993 (permalink) |
Once I solve the cooling issue (soon), she's going to hit the rollers again
#994 (permalink) |
EGR is GONE and as such, the DPFE is simply "tubeless", but MUST remain connected to the engine harness or you get a CEL. The EGR blockoff plate is tapped as my boost signal source for my BOV and boost gauge/waste gate controller.
#995 (permalink) | |
![]() ![]() What is that long hose going from the front of the W/A intercooler around to the IACV area? Is that water and it just looks to be plugged in the IACV, but instead is going behind it to the firewall heater hose connection???
#996 (permalink) | |
Oh Dan did that originally and then admitted it was not a good way to go.
EDIT: Okay, so I was remembering that he tried plumbing the PCV into the IACV and that did not yield a happy ending. Quote:
#997 (permalink) |
Not a good idea to go "pre" or "post" turbo on the IACV feed?
#998 (permalink) |
Of note, I did find a quote of Dan suggesting the IACV remain post turbo!
But since he gave you different advice, perhaps he has changed his mind in light of his experience with the ADC kit. Dan?
#999 (permalink) |
Yes, that's the exact same thread I was reading before you replied: Did'ya ever have that "not fast enough" feeling? .82 A/R install... - his last comment on the last page.
#1000 (permalink) |
Who knows. I can see it both ways now. Damn- The IACV hose is after the intercooler, as the pics showed- But I can see it from Trevor's POV too. I never had trouble with the IACV, though. Lucky?
Oh, what to do?! BTW: POST #1000!!!
