#341 (permalink) |
Good stuff. I look forward to seeing those numbers so I can decided if I want to put one of these in my cougar on the brand new SVT engine I have in her.
1969 Triumph Spitfire MK3 1996 Audi A4 V6 5-Speed 1999 DT Green V6 MTX Built 8/7/98. She's got a few mods. 2004 Explorer XLT, V6, Auto, 4x4 |
#342 (permalink) |
Any updates?
http://www.cardomain.com/ride/1804161 Check out my slow progress... |
#343 (permalink) |
Nope, waiting for parts from the machine shop. Went to pick them up yesterday but they missed something on the design so they need to machine them a bit more.
#344 (permalink) |
Capital Curmudgeon
Question for you, sorry if this was answered already: if one were to purchase a kit for a 2.5L, how much would change to make it usable on a 3L later? (Probably not much, I'd guess...)
#345 (permalink) |
There would only be minor changes to the intake piping IF you had a full 3L. With a ported 3L there would be no difference.
#346 (permalink) |
Update:
I recently changed to 42lb injectors on my car because I was noticing the 19's were starting to lean out at the top of the RPM range. I had to work through my SCT software but I was able to get things going after finding a file on the SCT site for the 42lb injectors. I also switched to the smallest pulley vortech makes 2.62" to increase the boost to around 12psi. It seems like I'm running into a belt slip issue after about 6psi. I don't think its a tension issue because the belt is very tight. I'm guessing I've reached the limits of what you can do with two pulleys (one main drive pulley and the supercharger pulley). I suppose that is why most have idler pulleys for more belt wrap. The recent delays have mostly been because I can't figure out where I want to go from here. I don't want to sell a kit that may have belt slip issues. There are some major room constraints so a idler setup is going to be difficult to add. I'm sure I'll come up with something. Chris
#348 (permalink) | |
#349 (permalink) |
24lb injectors would be fine. I do have a bottle of belt dressing which would probably stop any slip but it seems like a temporary fix.
#350 (permalink) |
now.. i am not sure if i totally understand belt slipping...
ur saying at top RPM.... the belt is in spinning motion with the pulleys ( correct me if i am wrong which i am sure i am).. Altanator, A/C, Crank, Power sterring, and the SC pulley.... the belt just slips off? ![]() wouldn't the whole engine knock off if that were the case?
